Steering Column Levers.
On the column where the rod to the transmission connects. Some columns have one lever for the rod. And some have another lever that doe's not move.
Why is that. Mine has two. I am looking for a tilt. And I don't want to get the wrong one. Maybe you can see what I mean in my pic. I have a 69. What year tilts will work? Thanks, Grady Last edited by grs; 06-17-2010 at 07:32 PM. |
Has more rust than truck...
Re: Steering Column Levers.
I'm going to guess your truck or atleast your column was originally for Three on the tree. 3OTT uses the two levers.
I have seen other trucks that are AT, and they have the same column.
Cruzin
you talking about the green area? that on autos for the nipple (red) to rest in the different areas when you move to different gears, i think all autos were that way maybe this is what your looking for? the manual columns will have two levers for the rods to go in
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
if looks like mine must be 3 on the tree
c1069 yea that is for a three on the tree i have the same one on my truck
That explains alot i've got the same column on my 72 auto I knew that linkage didn't seem right when I converted the p.o.'s floor shifter back to column shift
Hubscrub you are right. Mine is an automatic. But I have seen automatic columns that have only one lever.
I think the tilt columns have internal detent plates so you will only see the shift lever.
Thanks, I am looking for a tilt. Hope to find one near Chicargo. I am in Joliet, Il.
