06-20-2010, 09:17 PM | #1 |
been here longer than Liz
resurrection
So I figure after a 5 year timeout in the driveway, it might be time to get the ride back on the road. I've got a very limited budget for the time being ($500) on which to cover whatever it is that will need to be done to get my fuel system back in order. I had a long talk with Chris Friday night which I think may have solved 1/2 my problem. After that I'll have to retread & get my windows rolling again. Oh yeah, and a battery.
1987 TBI with a fresh (less than 100 mile, more than 5 yr old) engine. Poly cell in the rear between the rails with an exterior Delco pump (no idea if it's still good). Some rewiring & plumbing will be needed. Here's some pics from better days; And some depressing pics from Friday night;
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
06-20-2010, 09:35 PM | #2 |
Re: resurrection
Nice truck. Its good to know that your getting back into it. Good luck with the truck pal.
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
06-21-2010, 02:36 PM | #3 |
Re: resurrection
Thanks Rollinsqrbdy. Just working on the parts list now to see what I can accomplish.
-fuel line to TBI (Thanks Captkaos) -battery -tires (P225/60R16 & 255/50R16) -new deck plate for the bed -wiring from firewall to fuel pump -fuel pump? Not sure if the pump I have now works. Problem with doing all this so long ago is I've forgotten what I learned then. I don't have a sending unit & I'm running an external fuel pump. Maybe that's part of my problem? Chris said Strret & Performance uses the internal pump & sending unit inside the poly tanks. Might switch to that if I can. I know the parts list will magnify as I get into the repairs. Any suggestions on the above would be more than welcome.
06-21-2010, 03:11 PM | #4 |
Getting Old; Going Broke
Re: resurrection
What do you mean by deck plate for the bed? Might be something I have here you can make work if I knew exactly what you were talking about.
06-21-2010, 04:06 PM | #5 |
Re: resurrection
Randy,
I have a boat deck plate in the bed floor like this; that I open to gain access to the fuel cell cap. The one in there now is black (and cracked), I used weatherstripping in the corrugation of the bed along with copious black silicone. Ideally I could use something metal & welded into the bed floor like Jeff did.
06-21-2010, 04:08 PM | #6 |
Re: resurrection
Ahhh, gotcha. I was thinking you needed a piece of bed floor or the rear sill or something. About all I can offer is an extra factory fuel door or two.
06-21-2010, 04:33 PM | #7 |
Re: resurrection
I appreciate it, but I've got two of those myself that I'm not using.
