Old 06-21-2010, 01:26 PM   #1
rvp183
little help with lowering questions please.
Hello all, recently purchased a 72 Custom Deluxe. It needs exhaust and shocks so I thought I would Drop it a bit while we were "at it" The question is...I want a relatively flat ride, perhaps a bit higher in the rear, not slammed to the ground and no desire to bag it. What is the mose economical and safe option? What is practical for a daily driver? Drop Spindles, Lowering springs? Honestly have never done this kind of work and need some advice. Thanks! Rich
rvp183 is offline   Reply With Quote
Old 06-21-2010, 01:27 PM   #2
rvp183
Re: little help with lowering questions please.
Also, Any source out there for a blue Highlander seat cover for my '72 bench?
Old 07-02-2010, 06:24 PM   #3
bcutt
bcutt's Avatar
i would check out CPP (classic performance products) they make front and rear drop kits including drop spindles, coils and shock relocating brackets for under $600.
bcutt is offline   Reply With Quote
Old 07-02-2010, 06:54 PM   #4
john
member #16
john's Avatar
Heres a company who sells the highlander material. You can get a sample from them.
http://www.smsautofabrics.com/?gclid...FRfOggodXwhGaQ
john is offline   Reply With Quote
Old 07-02-2010, 06:54 PM   #5
cdowns
cdowns's Avatar
loads of cheapos get kits and while the thing is apart never address the 40year old parts that they reuse// balljoints tyrod ends trailing arm bushings swaybar bushings control arm bushings i'm not a fan of old used abused 40year old suspension parts// i've never found a way i've felt safe with the cheap job metod of lowering
Old 07-06-2010, 05:04 PM   #6
rvp183
Thanks, I just bought a 3/5 drop spring kit, c-notch kit, slammer shocks, and an adjustable rear bar to keep the rear end in line. Now the question is "rims and tires" I have some old school Cragers with 255 70R 15's on them, I hope they don't look too small...what do you think?
Old 07-06-2010, 06:50 PM   #7
bcutt
bcutt's Avatar
Its all a matter of what you like, personally i like something a little bigger but for a daily driver with a good ride quality they should be just fine (and look good too). Post some pics when your done, we'd love to see it.
Old 07-06-2010, 07:09 PM   #8
epashhans
epashhans's Avatar
I got the 3/5 from CPP. Its nice and everything was of good quality. Only one problem...I now want to go lower. I've heard that can be a problem...
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 07-02-2010, 07:28 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
For the front, I prefer spindles vs lowering springs. Go for a 2.5" set from CPP or check out our Vendor Marketplace for some great deals on DJM. If you need a bit more try cutting 1/2 or 1 coil off your stock springs. Cut them, do not heat them.
For the rear, try the Jeep spring conversion. They are cheap and give you 3-4" of drop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-02-2010, 07:39 PM   #10
BIG ORANGE
BIG ORANGE's Avatar
Just swap out a 6lug front carier for a 72 carier and cutt 1 round out of the front springs at the bottom of the springs! Done this numeruos times!
Gonna get a stick a thick wall 2" square tubin and cut 2 pieces 7" long and drill 2 holes for the longer U bolts I pick up at Advance Auto Parts and set the back down for a nice level ride.
When I'm done I'll have less than 25.00 buck in dropping the 69!
Swappin out the 6lug rearend for the 72 5 lug also!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
