Hey I'm in a fuel delimma right now. I'm torn between buying a fuel cell and making my own fuel tank. My company makes "water tanks" quite a bit with no problems, so that's not a concern. What I'm a little worried about is my application. I have a '79 Chevy Blazer that I bobbed the rearend off of. This is an extreme rockcrawling 4x4 so fuel slosh is going to happen. I'm putting a partition in right behind the back seat and in this way creating a mini sort of short bed. I'll put the tank in the bed and a custom size would be optimum. What do you guys think about making my own so I can take advantage of the space available? How should I place the baffles and what should I make the tank out of? 16 ga was my first thought, with corrogated type top and bottom for rigidity. Can I use my stock lines, filter ,and all that? What to use for a pump? I dont want high pressure as I have a stock 350. Any help you guys can give would be appreciated. I've asked a lot of questions with the off road type guys, but the street guys have been playing these games a lot longer. So I appreciate your advice. Btw, I'm looking at between 26 and 35 gal.
Bryan ------------------ Clunk whap whap whap...ahh the lovely sound of my driveshaft breaking... Locked, Loaded, and ready to break $hit!!!
Clunk whap whap whap...ahh the lovely sound of my driveshaft breaking... Locked, Loaded, and ready to break $hit!!! |
fuel cell with the foam. better all around deal. no fuel slosh, fuel fittings allready installed etc. much safer. these things do turn over. good luck
BAD BOW-Silverado XST
I'm no 4X4 guru but agree with roland26. Use the foam cell. Since extreme tilting will be exprienced, I would use an electric pump with a manual cut off switch installed too. Your stock fuel lines should work once you modify the ends to fit the electric fuel pump. Block plates for the fuel pump/engine block are realy easy to find.
------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" http://www.geocities.com/abetterchemist/ |
| Bookmarks |
