guage cluster
I have been looking for a guage cluster with tach for my 86. I want one from a 80 model or later. If anyone has them installed I sure would like to see pics because I have only heard of these never seen one.
Re: guage cluster
This is the one that came in my '87 -
K ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Getting Old; Going Broke
Re: guage cluster
Wow, I was unaware they even offered a tach in 87. That makes me want.
#4 | |
Re: guage cluster
Sorry for the double post, but wanted to bring it back up. I did some reading today and found this:
#5 | |
Re: guage cluster
Frank
Born and proudly residing in a Red State ! |
Re: guage cluster
I don't think they came factory, but you can put one in even with the VSS, but requires some wiring work.
If you don't have the 91 with VSS, but a 90 and older, it's a plug and play. I put a cluster from a 79 in my old 87, but used the 87 speedo. Worked/looked like factory, save for the white overlay.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Oh,you can't buy that new
![]() Join Date: Apr 2000
Re: guage cluster
randy, no difference for an 87 TBI, tach feed is off separate coil on back of intake instead of the HEI cap.
try this link but it is wrong about the 87- hopefully jeff will catch this, i wrote most of that info for him a long time ago. http://www.73-87.com/7387garage/inte...achometers.htm AGAIN- there are 4 distinctly different units for the years. 73-75 76-77 78-79 - plug-n-play in 80 up also if you like the 100 MPH speedo. 80-87 - yes in 80 not 81 they changed the font. and AGAIN 90% of the sellers on ebay have no idea what they fit and what they will cause a dash fire in by mixing them up. crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
Re: guage cluster
Is why I rang you a PM Crossy, the article said you were the man to know.
![]() What about a cluster out of a 77, would it work for the 87? Last edited by RandyP; 06-22-2010 at 10:28 PM. |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: guage cluster
Yeah '82 was the last year for a factory installed tach in the squarebodies UNLESS YOU HAD KEITH's line of connections as stated above.
I've got a tach installed in my '91 Suburban as well See how I went about doing it on the link in my signature below
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Re: guage cluster
Wow BLE 'BURBAN, that's nice. A bit more work than I want to do, but your end result is awesome. I thought I read that the tachs out of those large trucks would not work in the 1 ton and downs, maybe that is why neither of your other two tachs worked right? But still, awesome looking cluster there.
