T5 Swap Done.
Anybody with a 3 speed that wants to put something else in its place is crazy not to to the T5 swap. I got less than $300 in it and its smooth as silk.
I used the Hamilton T5 plate, got a 14 spine 10" s10 clutch plate, and used a 78-81 2 door malibu drive shaft with 1 1\4 inch took out of it. Cut the drive shaft ourselves. Never again will I pay to have it done. Stuck it back in the truck and put a indicator on it and got it running true and started welding. But the straight 6 and T5 is awesome. Ive ran it probably 6-700 miles in 2 weeks. Parked my Nissan and been driving to work everyday. Here is a few pics I took today at lunch at a old rail yard. ![]() ![]() ![]() |
Rollin' Old Skool
Re: T5 Swap Done.
great to hear....& the truck is looking good!
Resistance is Futile
Re: T5 Swap Done.
Nice. Good way around the too low geared rear axle, too. What rpm are you turning at freeway speeds?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: T5 Swap Done.
Dont know I was wondering that myself. Just guessing prob 2300-2700. Just a guess. Also I ordered a CPP crossmember. I didnt use it. I may be wrong but I didnt think it would hurt just running it like a 3 speed without one. The length is longer of course. But weight wise they are pretty close. I hadnt had any issues and it seems to be very smooth. Alot smoother than I was expecting. Just thought I would throw that out there for anybody that is planning on donig the swap.
McMullin
Re: T5 Swap Done.
What kind of MPG are you getting after the swap?
Re: T5 Swap Done.
how hard was it to locate and mount the slave cylinder on the firewall? I'm planning on doing this swap only with a nv3500 in the near future and this is about the only thing holding me up
Ben _____________________________________ 1971 Chevy shortbed 350/4-speed sold 2005 Chevy Duramax EC/4x4 Local 597 Pipefitters certified TIG MIG and stick welder |
#7 | |
Re: T5 Swap Done.
Ray |
Re: T5 Swap Done.
Correct. If your going with a nv3500 you will have to have a hyd. setup. I looked at it before I went this route. And I believe that if you took and indexed the splined arm at the end of the clutch shaft under the dash to where it would push a rod out the fire wall like a brake rod you could put a clutch master cyl where it falls pretty easy. That way you can use your stock pedal assy. Of course I didnt try it but I believe it will work pretty easy.
Re: T5 Swap Done.
nice ride
Phone's ringin Dude.
![]() Join Date: Mar 2007
Re: T5 Swap Done.
Dude I love your truck!
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
Re: T5 Swap Done.
what kind of hp is the t5 rated for? I see that you put it behind a straight six but I've got a mild 350. I'm not going to go crazy with the motor but I want to be able to get on it every once in a while. My truck is just a cruiser that has already seen a good bit of highway driving so the overdrive is becoming a must. I'll have to look into the t5 just for the ease of installation.
#12 | |
Re: T5 Swap Done.
Re: T5 Swap Done.
I am thinking about doing the swap. Did you get one out of a camaro or a S10? Is the shifter location at the end of the trans or more towards the middle? BTW, your truck looks great. Stance is spot on.
Boucher
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
#14 | |
Re: T5 Swap Done.
And thanks. I dig your truck too Ive been keeping up with your turbo build. Im looking for a 292 to do something pretty wild with. I want one to rev and sound like this. Last edited by CWT; 06-23-2010 at 11:04 AM. |
#15 |
Re: T5 Swap Done.
Wow. That video is making me second guess my turbo project. I love the way that engine comes back to idle so quick after a throttle shot. It reminds me of those top fueler's from this weekends hot rod reunion drags. From what I have seen, you can pick up an engine for next to nothing. A intake and headers usually cost more than the whole engine itself!
The turbo project has been a blast. Just like anything, its mostly tuning now and resisting the urge to turn up the boost! I have been putting some major miles on it lately and is really reliable. I need to upgrade the ignition with HEI it is running off a converted points system. Then to S10 5 speed. Are you headed to any shows?
#16 |
Re: T5 Swap Done.
too hot, I hear that. I just got a flyer on the Dragstalgia over the weekend, looks like fun. I have never been to the Redneck Rumble and want to go. A killer show is the Goodguys at Bowling Green in October. See ya around.
#17 |
Re: T5 Swap Done.
Yeah I had a room and all for BG last year and had to cancel the day before. Me and my wife may ride up to Nashville in my truck one weekend to just hang out. I may Pm you and see if there is any good cruises that weekend. Catch you later.
#18 |
One foot in front of the other
![]() Join Date: Aug 2008
Re: T5 Swap Done.
Truck looks good
#19 |
Re: T5 Swap Done.
are there many differences between the t-5 in an s-10 and one from an f-body? I just found one out of a firebird for a decent price. I'm putting buckets in my truck so shifter location isn't critical. where did you get your clutch kit from and about how much? thanks
#20 | |
Re: T5 Swap Done.
On the plus side, the F-body input shaft is the same length as a stock 3 or 4 speed, so you won't need a spacer plate (I shortened the shaft pilot and bearing retainer on mine, which is another way to do it). Also, the V-8 transmissions (but not the V-6) are stronger than the S-10 version and have a 26 spline input shaft instead of 14. My truck had an 11" clutch, so I bought a rebuilt stock disc (only) for a 4.3 Astrovan. I re-used my pressure plate and throwout bearing, which had only a few miles on them. The disc cost about $30 plus the core charge. Ray |
#21 |
Re: T5 Swap Done.
thanks for the info!
I might just have to pull the trigger on this and sell my nv3500. Seems like a pretty straight forward install. I'll get a new clutch kit though as mine is shot in my truck right now anyways.
Ben _____________________________________ 1971 Chevy shortbed 350/4-speed sold 2005 Chevy Duramax EC/4x4 Local 597 Pipefitters certified TIG MIG and stick welder Last edited by Schwinn68; 06-23-2010 at 02:23 PM. |
#22 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: T5 Swap Done.
Nice job, and thanks for sharing the info for everyone! This would be a great swap for alot of guys I'd imagine.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#23 |
![]() Join Date: Oct 2006
Re: T5 Swap Done.
nice very nice
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#24 |
Jonny
Re: T5 Swap Done.
Another good bit of information! I was thinking the only way to get an OD transmission with a mechanical clutch was with a FY6.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#25 |
Re: T5 Swap Done.
i have a T5 out of a 1989 S10 which has the electronic speedo drive & i want to do this conversion on my 66 C10 but i want to use my cable drive speedo, what do i need to do? is there a kit or something?
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
