Can you tell how many times it's been painted
Look how many times this truck has been painted looks like a good ACID TRIP.
It's melting!!!! dude relax black,green,yellow,red,gray.and green and now going to be blue.
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR" ![]() |
Re: Can you tell how many times it's been painted
Your truck is bleeding!!! Quick, get some towels STAT!!!!!
That's what my chevelle looked like when I stripped it.
I'm not as good as I once was, But I'm as good once as I ever was. |
On the path to financial ruin!
![]() Join Date: Jan 2009
I think most cars and trucks about 35 or 40 years old have undergone a many of paintings. LOL!!! Are you gonna take it down to the metal?
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
Yeah, you better strip tht thing all the way down to bare metal so you can start with a solid foundation.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
Black is epoxy, green color is base coat, yellow is a primer, red is a base color, gray is a primer, and green is a base coat. So i will say your truck was painted 3 colors in its life. (green, red, green) and now your blue!?!?!? That is WAY to much paint on any truck!!! I would strip it down and start with bare metal!! Other wise there is a good chance of having MAJOR paint issues!
Black,is your factory Primer..green was the factory color,yellow is a old promer sealer from the late 70's ,red was the color they painted over the yellow primer sealer,gray is a either a primer or a sealer they used before painting the truck Green. more likely the Gray is a sealer to block a reaction to the old lacquer paint.
thats alot of paint and primer....I would thin it a little by sanding the truck down as far as you can to keep your New Blue from cracking and checking if its lacquer paint ....just my opinion, Im sure you will get 100 other opinions
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
I say clearcoat it, throw some TT2 on it and call it a day. I like it!
The only thing I am worried about is that the old paint may contain lead so I was not planning on going that far. And cannot afford to have it media blasted. I was going to put on some high build primer, primer sealer and have it painted. Is that a bad idea I just do not know if the old paint was lead based and it is not going to be a show truck just a weekend driver.
