Old 06-24-2010, 03:01 PM   #1
chisler
chisler's Avatar
Dana 44
I can pick this up for 100 bucks,will it work for a spare for my 72 k10 and is it worth it for parts, ( the axles/spindles etc ) ratio is 3:07 according to diff tag other casting numbers are 445CF C36585 146CF and on the tube the numbers are 59 5AF 603454 my ratio in my truck ratio is 3:73 so the gears will not work,but for the rest of the spare parts ?? not a expert on this but are lots of these diffs still out there or did they change after 72.Thanks chisler
chisler is offline   Reply With Quote
Old 06-28-2010, 01:24 AM   #2
chisler
chisler's Avatar
Re: Dana 44
I ran the material numbers and came up with 1974/75 as this being manufactured ,but the axle shaft numbers are different then the 1972 year would the axle shafts /spindles still work, To any one??
Old 06-28-2010, 09:56 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Dana 44
The shafts will still work, just need to use a different seal. The shafts also use a bigger u joint..stronger= better.
Everything will work.
$100 is a fair price. Does the pass side have a flat top knuckle? If so its deff worth $100.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-28-2010, 01:41 PM   #4
chisler
chisler's Avatar
Re: Dana 44
OLDCHEV4X4, I picked up the diff, thanks for the info, I also took some more picks of the pass side and it is a flat knuckle on top(pretty sure)are these getting hard to find ,I now have a project LOL Thanks chisler
Old 06-28-2010, 03:07 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Dana 44
Yes, that is a flat top knuckle.
You win!
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
