Old 06-24-2010, 06:15 PM   #1
72chevy383
Tire size 20 x 10
Can I use this size tire on my 71 c/10 with a 4" drop in the rear and a 2" in the front, or anyone have idea's?
72chevy383 is offline   Reply With Quote
Old 06-24-2010, 08:37 PM   #2
jasonb72
PorterBuilt Man Crush
Re: Tire size 20 x 10
I know you meant Wheel size not tire size, and yes it can be done but it depends on the backspacing of the wheels.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 06-24-2010, 09:19 PM   #3
72chevy383
I think the guy told me 6 1/2 on the spacing.
Old 06-24-2010, 10:55 PM   #4
frednoah
86 Scottsdale
Could be tight. The 20x9's I took off my truck are 5 1/2, and they were close to the inside of the wheel tubs. You'd need to test fit the combo on your truck to be 100% certain on fit.
frednoah is offline   Reply With Quote
Old 06-25-2010, 07:41 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
You'll need to run a spacer with that much backspacing.
Keith
Convert to disc brakes.
Old 06-24-2010, 09:38 PM   #6
jasonb72
Do a search in this thread, I know it was talked about recently. I will try and find it to.
Old 06-24-2010, 11:36 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Running 20x8.5's and 20x10's on my '69, but there are a lot of things at play.... check out my build thread for more info.
Billet Specialties Vintec's
Front: 20x8.5" w/ 5.5" BS
- Center Bore: 3.430
- Bolt Pattern: 6 on 5.5"
Rear: 20x10" w/ 4.75" BS
- Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43])
Toyo Proxes S/T ii's
Front: 255/40-20
Rear: 295/40-20
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
