Better late than never
![]() Join Date: Dec 2001
Clutch Slave Cylinder
I've seen reference to this in the shop manuals. My truck doesn't have one. I'm going from a 3 speed to a 4 speed trans., & I'm wondering if this is an upgrade I need.
1) what is it? 2) do I need one? Thanks
1970 C/10 SWB Stepside |
If you're talking about 67-72 trucks, they didn't come with em (at least the 1-ton and smaller didn't) and you don't need one unless you're upgrading to a newer style trans and clutch...
Anyone know when they first appeared in chevy trucks? I'm guessing some time in the late 80s...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
its all about the +6 inches
A stock truck has a mechanical linkage. A steel rod that goes from your clutch pedal to the inside of your tranny which physicly disengages the clutch when you put your foot on the pedal.
On a newer set up, it works like the brake pedal. The pedal pushes a piston in a clutch master cylinder, which moves the fluid in a hose, then pushes the slave cylinder, which disengages the clutch. The pros are; lighter pedal presure no linkages to mess with Cons are all custom fabbing to install in old trucks cost of replacement parts More dot 3 fluid to eat your paint when it springs a leak Many old school ppl (like many of us on here) like the rod clutch for its simplicity. You can pop the hood and tell if it is all working properly. |
Fabricate till you "puke"
Some of the older pick ups had hyd clutches (early 60s)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Good deal...one less thing to do.
Thanks guys.
