06-26-2010, 03:36 PM | #1 |
No power after valve adjusment
Ok all I just did a valve adustment on my in line 6. Umm now it's sputtering and has no power. Did I snug them down to tight???????
HELP A BROTHER OUT PLEASE... Thanks
1979 GMC Sierra 15 1986 Danco Rollback 454 4spd 1986 Jerr-Dan Rollback 454 4spd 1978 GMC Jerr-Dan 454 Tonawanda 4spd FOR SALE 85 Chevy Wrecker 454 4spd AATAC Always a Friend...Michael |
06-26-2010, 04:05 PM | #2 |
Re: No power after valve adjusment
i'd loosen them up and start from step one in the service manual
06-26-2010, 04:22 PM | #3 |
Active Member
Yep, sounds like it. There's a procedure to do them with the engine not running. I usually prefer to do them with the engine running.
What was the reason for the adjustment? Normally, once you adjust them they should stay in place unless the rocker nuts get loose. If they were making clicking noises, you probably should replace them. If you tightened them to get rid of the clicking, you probably bottomed them out --not good. |
06-26-2010, 05:12 PM | #4 |
What?
Hydraulic or solid lifters?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-26-2010, 08:18 PM | #5 |
Active Member
Unless the cam and lifters were changed, they're all hydraulic from the factory.
06-27-2010, 10:02 AM | #6 |
You probably have varnish built up in the lifter. Readjust them. Back the adjustment up till the rocker has a little play in it & tighten it down 1/4 turn.
06-28-2010, 12:05 AM | #7 |
Location: Aurora,Il ..born,raised and still live in the same house
start it up and start with the first one. Loosen it till it "clacks" then tighten til the "clack" is just barely gone,then 1/4 turn.
Then next one. clack= flopping around
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL Last edited by beebster; 06-28-2010 at 12:08 AM. |
06-28-2010, 11:46 PM | #8 |
Ok im going with some solid lifters in this puppy. Gonna run this 6 banger till im ready for the BIG DAWG.....
Thank You all for your help.
