06-26-2010, 06:47 PM | #1 |
thinking out loud...Trailing arm Xmember question
Im looking to see if you could move the trailing arm crossmember up to change your wheelbase from long to short.
Then chop the frame off somewhere behind it and do a custom backhalf. Just a thought.. Last edited by edflores; 06-26-2010 at 06:47 PM. |
06-27-2010, 09:03 AM | #2 |
Re: thinking out loud...Trailing arm Xmember question
Sure you could. Anything is possible w/the right plan, tools, & skills.
06-27-2010, 09:16 AM | #3 |
PROJECT 7DEUCE
Im sure that would be very do able make it easy on yourself and buy an aftermarket trailing arm crossmember put it in the frame where you want it and build the back half off that..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-27-2010, 12:15 PM | #4 | |
But I just wanted to see if anyone had done it before. Seems easier than shortening the frame for what I want to do with the truck. |
06-27-2010, 04:41 PM | #5 |
Someone else asked the same question recently because he didn't want to deal with moving the cab mounts. I don't know if he ever got an answer.
It looks like it should be doable, but I'm not sure if it will actually be less work overall. You will still have to deal with the spring mounts, box mounts, rear crossmember and a few other bits I probably forgot about. Ray |
06-29-2010, 12:28 AM | #6 |
Grandpa in the rustmobile...
for someone like myself (can weld but not gonna weld my frame together lol)
it SEEMS like it'd be easier to drill holes and cut rivits VS cutting frame/welding back.. idk free bump interesting.. I HATE RIVITS THO
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-29-2010, 07:48 AM | #7 | |
67-72 parts collector,…
They moved the crossmember forward to eliminate messing with the rear cab mount,... but they still had to cut the frame. Look here for the articles: Frame cut http://www.customclassictrucks.com/t...ech/index.html Trailing arm crossmember moving http://www.customclassictrucks.com/t...uck/index.html To me this would be more trouble than taking out the 12" of frame under the cab,... and slicing 8" off the rear frame rails.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-29-2010 at 07:52 AM. |
06-29-2010, 07:53 AM | #8 |
This is the entire set of tech articles for that project truck.
http://www.customclassictrucks.com/s...les/index.html
06-29-2010, 12:12 PM | #9 |
As i am bagging the rear, Im trying to weigh the pros and cons of doing it this way. Im still going to have to kick up the frame, still have to make bag brackets, shock crossmembers.
And I mean cut off the factory frame. not splice it back on. |
07-07-2010, 01:57 AM | #10 |
Any more input? I just bought a short bedsides so I need to get my game plan soon.
07-07-2010, 10:29 AM | #11 |
Your plan is a home built back half frame section using the OE truck arms as the rear suspension?
07-07-2010, 11:24 AM | #12 | |
Im not going to be using the coils, I have "hats" for the upper bag mount, I have an aftermarket shock xmember, and was going to get a longer adjustable panhard bar. |
07-11-2010, 05:01 PM | #13 |
I think what you're asking has been talked about before. The problem with your plan is the contours and width of the frame changes and that is why people cut their frames on the flat parts and move everything forward. In other words, if you just move the trailing arms and axle forward it will no longer sit under the humps and look pretty silly.
-Scott- Last edited by sjarrett71; 07-11-2010 at 05:55 PM. |
07-13-2010, 03:40 PM | #14 | |
07-13-2010, 07:47 PM | #15 |
The frame rails are for the most part straight in the area mentioned. On swb frames, the TA c.member is under the cab. On lwb frames, it's behind the cab. From the front of the bed toward the back is where the frame curves out.
07-21-2010, 01:21 PM | #16 | |
Next project: 1970 K10
Here are the dims for a SWB frame FYI.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-21-2010, 01:59 PM | #17 | |
What would you charge for that service? What should I pay to have someone cut my frame down, if i bring a rolling chassis? I dont see harm in me trying first to bolt up the trailing arm xmember.I'm going to by a PB one this month. This thing will be bagged, so bag mounts, relocated shocks, and longer panhard are needed regardless. the rear bed mounting looks to be the other issue, but i dont see it being a major problem. |
07-22-2010, 09:25 AM | #18 |
Sub'd
