Old 06-26-2010, 08:54 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
I am stumped
Can any of you guys tells me what this thing is just above me oil filter on the driver's side of my block? The guy I bought the motor from was running a 700R4 behind the motor. Also for any of you running a manual tranny, where do I mount the block ball std for the bellcrank? If I remove this little do dad I should be able to mount the ball stud here????
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 06-26-2010, 09:11 PM   #2
badchevy
Re: I am stumped
My truck also has that sensor. If I remember correctly, I believe it is a oil pressure sensor.
badchevy is offline   Reply With Quote
Old 06-26-2010, 09:15 PM   #3
ol_skool_chevy
ol_skool_chevy's Avatar
Re: I am stumped
I agree,, I think its a pressure sensor.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-26-2010, 09:22 PM   #4
cableguy0
Re: I am stumped
That is the oil pressure sensor. The hole above that should be for the clutch linkage. It might not be tapped for a bolt yet. Some werent from the factory.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-26-2010, 10:15 PM   #5
joe231
joe231's Avatar
Re: I am stumped
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-27-2010, 10:33 AM   #6
ECU PIRATE
ECU PIRATE's Avatar
Re: I am stumped
Thanks guys. Since I don't have electrical gauges, I will leave it unplugged or should I move it when I re-install the mechanical oil pressure gauge? The hole above it is tapped but I thought that was one of the mounting points for the starter. I am. Hanging the starter any way to match my small block flywheel
The Fleet........
Old 06-27-2010, 11:12 AM   #7
LONGHAIR
Re: I am stumped
The starter goes on the other side of the block, at least for automatics. The starter bolts directly to the bellhousing on most truck-type manual transmissions.
As the others have stated...the fitting is for oil pressure and the hole above it is for the clutch bell-crank.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-27-2010, 12:26 PM   #8
1LowToy
Re: I am stumped
Don't just take that senging unit out. It will have to be plugged or you will have a gusher of crude oil coming out when you start it up. I believe thar is another oil passage next to the distributor.
1LowToy is offline   Reply With Quote
Old 06-27-2010, 12:34 PM   #9
83burban
Re: I am stumped
My 83 gas that sensor. It is an oil pressure sensor for the electric choke. You connect the oil pressure sensor to the fitting on the top of the block next to the distributor. This sensor controls the choke on a quadrajet for cold start or something like that, Im sure someone else can clarify that last part.
83burban is offline   Reply With Quote
Old 06-27-2010, 09:31 PM   #10
clinebarger
Re: I am stumped
Yes it is the choke switch. It connects power to your choke after the engine builds oil pressure.
clinebarger is offline   Reply With Quote
