Old 06-26-2010, 09:19 PM   #1
rennalds
2004 sierra tie rod ends
Anyone ever replaced 2004 tie rod ends both (inner and outer)? Is it better left to the dealer or should someone with weekend skills be able to pull this off???
rennalds is offline   Reply With Quote
Old 06-27-2010, 12:05 PM   #2
truckdude239
truckdude239's Avatar
Re: 2004 sierra tie rod ends
well if its the same as a tahoe i did a guys at works in about 20 mins plus the 30 mins for alignment at the shop up the road. if it is 4 wd that are simple 2 wd not so much
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-28-2010, 03:23 AM   #3
rennalds
So you are saying a two wheel drive is harder?
Old 06-28-2010, 06:43 AM   #4
truckdude239
Yes
David fuller
2000 Tahoe 5.3l 378
Old 06-28-2010, 06:46 AM   #5
truckdude239
2WD HAS A RANK AND PINON which are harder to the fact you have to take the boots off the rack and have a special tool for it. the 4wd are right there on the outside where you can get to them it a big wrench it calls for .5 a side on the 4wd and 1.0 hour per side for 2wd
David fuller
2000 Tahoe 5.3l 378
Old 06-28-2010, 02:59 PM   #6
rennalds
I have been reading up on it. Is it possible to damage the rack when removing the tie rod? What tool should I ask for at the parts store?
Old 06-28-2010, 07:13 PM   #7
truckdude239
you need an innner tie rod tool http://www.harborfreight.com/inner-t...set-96558.html is what it looks like
David fuller
2000 Tahoe 5.3l 378
Old 06-30-2010, 11:41 AM   #8
rennalds
What about the boots? Are they reusuable? Is there a special tool for removing/installing the boots? Thanks for all your help!!!!!!!!!!!!!!!
Old 07-01-2010, 07:14 AM   #9
truckdude239
they are reusable if they are not ripped not special tool i just cut the clamp that holds them on the normally i use a zip-tie to hold them back on
David fuller
2000 Tahoe 5.3l 378
Old 07-02-2010, 06:56 PM   #10
bighaas79
small hose clamps will work as well
bighaas79 is offline   Reply With Quote
Old 07-02-2010, 07:30 PM   #11
truckdude239
yeah a small hose clamp would probley work better
David fuller
2000 Tahoe 5.3l 378
Old 07-03-2010, 10:03 PM   #12
rennalds
A big Thanks to TRUCK DUDE!!!
Old 07-03-2010, 11:11 PM   #13
truckdude239
did you get them done?
David fuller
2000 Tahoe 5.3l 378
Old 07-03-2010, 11:54 PM   #14
rennalds
yep worked like a charm, thanks again
Old 07-04-2010, 09:36 AM   #15
truckdude239
no problem glad i could help!!
David fuller
2000 Tahoe 5.3l 378
