Old 06-28-2010, 05:57 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
What kinda oil pressure is your motor running?
Just finished my 406 recently and was wondering how much oil pressure on you running fully warmed up in drive at idle? Just curious. Mine is about 25-30 pounds in gear after i have drove it a while. When i get going down the road cruising it hangs around 55-62.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 06-28-2010, 06:03 PM   #2
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: What kinda oil pressure is your motor running?
we were actually just talking about this.
http://67-72chevytrucks.com/vboard/s...d.php?t=409269
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 06-28-2010, 06:08 PM   #3
BADPURPLE70CHEVY
406 Powered
Thanks I read it just now. Anybody else got an opinion on oil pressure.
70 GMC
68 c10
2002 silverado
72 4x4
Old 06-28-2010, 06:13 PM   #4
crapy67
White wall terror
crapy67's Avatar
Do you have a high volume oil pump in your 406? In my 71 nova with a 406 I have about 25 to 30 pounds at idle when warm, and It darn near pegs the needle when at full throttle, My pump is a Melling high volume
crapy67 is offline   Reply With Quote
Old 06-28-2010, 06:41 PM   #5
BADPURPLE70CHEVY
406 Powered
No high volume oil pump. But if i get in it pretty good it goes to about 70-75. Just worried about the idle in gear pressure after warm up.
70 GMC
68 c10
2002 silverado
72 4x4
Old 06-28-2010, 06:12 PM   #6
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Thats plenty! now get out there and drive the wheels off it!
mikajo39 is offline   Reply With Quote
Old 06-28-2010, 06:52 PM   #7
trusty72
trusty72's Avatar
no problem, if i remember right 10 pounds per 1000 rpm is enough per the engineers who designed it a million years ago. If you had more i would be worried, my 406 in my 10 inch tire drag truck would go from 80 pounds to about 10 right about the finish line at the dragstrip. it was a high volume/pressure and was sucking the pan dry, but i was turning it 8300 rpm.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-28-2010, 08:40 PM   #8
BADPURPLE70CHEVY
406 Powered
Just got alot of money tied up in it. Guess im worrying for nothing.
70 GMC
68 c10
2002 silverado
72 4x4
Old 06-28-2010, 08:44 PM   #9
68longhorn
68longhorn's Avatar
My 350 in my caprice has about 10-15psi @ idle(550rpm). I was told don't really worry about idle, worry about it at rpm.
68longhorn is offline   Reply With Quote
Old 06-28-2010, 09:04 PM   #10
68CEE10
68CEE10's Avatar
the 350 in my truck is the same way, really low at idle and about 45-50 cruising speed.
68CEE10 is offline   Reply With Quote
