06-29-2010, 09:25 PM | #1 |
Could someone I.D. these axles for me??
There is a family in town that is moving and they told me I could pick up the rolling frame from their '86 3/4 ton shortbed for the $50 bucks that the salvage yard was going to pay them. I figured if they were decent I would just buy it and yank the front and rear out from the frame and just save them, but am unsure as to what they are. I know they're 8 lug and the front has Warn lockout hubs, but that's about it. Can anyone fill me in?
Thanks. |
06-29-2010, 09:28 PM | #2 |
SWB 4x4 Collector
Re: Could someone I.D. these axles for me??
The front is a 10 bolt, but the rear looks like a Dana44 to me. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
06-29-2010, 09:46 PM | #3 |
Thanks for the reply, Trevor. Is the 10 bolt worth saving, or should I just grab the rear and junk the rest? I figured I would buy the chassis and just use the axles for trade stuff down the road if I didn't find a use for them..............
06-29-2010, 09:49 PM | #4 |
6>8 Plugless........
Does the rear axle have a hub or just an axle face? It should have been a 14 bolt non floater from the factory.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-29-2010, 09:54 PM | #5 |
I wasn't able to spend a lot of time out there, they're supposed to be out by the end of the week and I just hate to see something sent to the junk pile if it can be used. I'll try to get a better look tomorrow. Which axle has the hub?
06-29-2010, 10:03 PM | #6 |
SWB 4x4 Collector
That's no 14 bolt rear, 14 bolts don't have that buldge in the cover. That's why I say it looks more like a Dana 44 axle. The 10 bolt is worth more than $50, if that helps ya out. It's worth picking up. Trevor
06-29-2010, 10:17 PM | #7 |
Cool, I'll go ahead and grab them then. I had gone out to the guy's place because he listed a complete 4 speed and transfer case and when I went out to buy them I asked about the frame sitting in the driveway. Now to break out the Sawzall...........
06-29-2010, 11:54 PM | #8 |
Currently Blazerless
I agree with Drink2mny, its looks like a 14 bolt semi floater rear...this would have the 9 1/2 ring gear and started in 86 I believe. Take a look again and see if it is a 6 lug rear.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-30-2010, 10:28 AM | #9 | |
Support The Board |
06-30-2010, 10:36 AM | #10 |
SWB 4x4 Collector
Thanks drink2mny, I was always under the impression that 3/4 ton 4x4's received 14 bolts that look like Full Floater 14's. Had no idea this whole time, that the Semi-floaters didn't look anything like the FF 14's that I am used to. Trevor
06-29-2010, 10:00 PM | #11 |
Back looks like a 14 bolt semi float... was it a 6 lugger???
Support The Board |
06-29-2010, 11:59 PM | #12 |
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 06-30-2010 at 12:01 AM. |
06-30-2010, 12:02 AM | #13 |
Here is a nice site for identifying axles. A mod should make it a sticky.
http://www.venturesparts.com/index.p...identification
06-30-2010, 12:10 AM | #14 |
Like Trevor and others have said, the 10 bolt is worth it because someone can use the axles or use the hubs and such to convert another 10 bolt from 6 to 8 lug.
06-30-2010, 12:17 AM | #15 |
That rear is definitely NOT a Dana 44.
06-30-2010, 04:49 AM | #16 |
That rear is definitely a 14 bolt SF. It's a good upgrade for a 1/2 ton truck, but nothing special on a 3/4.
Ray |
06-30-2010, 11:48 AM | #17 |
Junior Member
dana 44 front and dana 60 rear 44 front ends are the same as half ton just has 8 lug roters on then not worth much if it was a dana 60 front end very rare to find then be woarth it
06-30-2010, 01:55 PM | #18 |
If you are trying to say that is what the pictured axles are...you are completely wrong.
06-30-2010, 11:50 AM | #19 |
Junior Member
o yea it is a 14 bolt rear that rearend is bullet proof very good rear worth taken that
06-30-2010, 03:06 PM | #20 |
This particular 14 bolt is not at all as strong as a 14BFF. Many differences seperate them.
06-30-2010, 10:18 PM | #21 |
All in all the full-floater is much stronger and more desireable, but the semi-float is WAY better than a 10 or 12 bolt. 33 spline axles are larger diameter than the 30 spline jobs in the FF as well.
06-30-2010, 10:38 PM | #22 |
Must be those parts are hard to find out there, I junked a couple sets of those. They are all over yards up here.
The 14sf rear in the 80s ALL had 8 lug, the 6 lug 14sf didn't come out till the NBS in 88.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
07-02-2010, 05:59 AM | #23 |
I'd grab it.
The 10 and 14 bolt could be useful, it has a lift kit on it, and assorted parts could go to ebay. |
07-03-2010, 06:01 PM | #24 |
that is a 14 bolt with a 9 1/2 ring gear . i payed $50 for mine with a whole truck attached . these are nothing close to the 14 bolt full float rear in away kinda of the junk 14 bolt . the front axle is a deff a 10 bolt witch is some what ok .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
07-03-2010, 09:39 PM | #25 |
I lost count how many were at the junkyard today....
