Old 07-01-2010, 07:04 AM   #1
72farmer
Anybody have trouble keeping inside window handles on when using thick door panels?
I never thought i would have trouble keeping these handles on since they are so hard to get off sometimes.My custom made door panels are 1/4" thick plus foam and vinyl.I get the clip on and when you use it rolling down the window a couple of times it pops off because the door panel is pushing out on the handle.Has anyone drilled out the end of the shaft on the regulator and put a small screw through handle.I know this would not look good but i may not have a choice.Could you use 72 regulators since they stick out more?
72farmer is offline   Reply With Quote
Old 07-01-2010, 07:56 AM   #2
cdowns
cdowns's Avatar
Re: Anybody have trouble keeping inside window handles on when using thick door panel
the regulator shafts are just so long// if you're going custom you may need to extend those shafts for proper operation
Old 07-01-2010, 08:12 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I ran into this too...I padded the steel panels then covered them in vinyl....what I found was that the clip was streched...pull it off give the clip a good squeeze and pop it back on...it has worked so far........
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-01-2010, 09:15 AM   #4
junkyardjohn
junkyardjohn's Avatar
72 window regulators do indeed have a little longer shaft, are completely interchangable with 67-71 reg.s & will probably solve your problem. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-02-2010, 04:47 PM   #5
72farmer
I drilled out the center of my left and right regulator shafts and tap threaded a 4-40 thread and got some stainless screws and drilled hole in handle and screwed the handles on.It actually looks pretty good but i just hope the small 4-40 screw holds and don't break or strip out.Time will tell.
Old 07-02-2010, 06:30 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
If you are using aftermarket clips they are junk and dont hold.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
