Old 07-03-2010, 10:54 PM   #1
jake wells
how do you get the sticky goo off the steering wheel
i have tried to get it off but what should i use to get it off?
im tired of having to wash my hands every time i go somewhere.
or which store can i get a cover that actually fits it's the stock
steering wheel.
jake wells is offline   Reply With Quote
Old 07-03-2010, 10:55 PM   #2
spinem
haha, ford guys...
Re: how do you get the sticky goo off the steering wheel
the 99c store, idk if u have one up there, but they sell a covering that will help that....
other method, JUNK YARD!!
p.s. might try rubbing alchol (91%) depending on how bad it is.
good luck
spinem is offline   Reply With Quote
Old 07-03-2010, 11:06 PM   #3
cableguy0
Try some goo gone. That stuff removes most anything. You can also try some heavy cleaners like super clean
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-03-2010, 11:25 PM   #4
35EmilioVasquez
degreaser
35EmilioVasquez is offline   Reply With Quote
Old 07-03-2010, 11:55 PM   #5
jake wells
thanks guys i got some engine degreaser so i think i might try it
Old 07-04-2010, 12:38 AM   #6
tucsonjwt
Go easy on that engine degreaser - could do some damage to the plastic on the wheel. Just us hand cleaner, like the gritty orange stuff or goo-gone as was already mentioned. Just rub it in straight with your hands and then wipe it off with a dry cloth. It will take a few applications, then wash the grit off with warm soapy water, then clear water. I do this like once a year. I have the leather-like perforated wrap on my steering wheel and I clean that just as described above. In fact, I have two of those covers on the steering wheel because I have become accustomed to the thicker steering wheels on the modern vehicles.
tucsonjwt is offline   Reply With Quote
Old 07-04-2010, 12:45 AM   #7
blaserman
blaserman's Avatar
I had one like that and I removed it and put it in a basin with hot water and soap and let it soak for a couple of hours and scrubed it off. Had to do it twice but it did come clean.
This is my best friend
blaserman is offline   Reply With Quote
Old 07-04-2010, 01:07 AM   #8
ol_skool_chevy
ol_skool_chevy's Avatar
Use sticky goo remover...you can buy it at the Gettin' Store
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 07-04-2010, 01:41 AM   #9
jake wells
the Gettin store
if the goo off doesn't work ill soak it in some warm soapy water
Old 07-04-2010, 03:11 AM   #10
86lovelongbeds
I work in the plastic manufacturing field and know a lot about plastics. From my experience in plastic, steering wheels are a covered in a form of rubber type resin. Once rubber is exposed to excessive UV rays and heat it breaks down the chemical make-up. This is the black sticky stuff, the plastic on the steering wheel has broken down and you will have to, more than likely, seal it with some sort of plastic repair coating. Kind of like clear coat for paint or simply replace the steering wheel.
I could be totally wrong but that is just my thoughts. Hope it helps.
86lovelongbeds is offline   Reply With Quote
Old 07-04-2010, 03:55 AM   #11
irishman999
irishman999's Avatar
Try using some incredibly harsh chemicals such as muratic acid and wire brush the hell out of it, if you have a wire wheel for a grinder that could work too just be carefull.
irishman999 is offline   Reply With Quote
Old 07-04-2010, 10:22 AM   #12
DPowers
One foot in front of the other
DPowers's Avatar
Then the next question would be....
"How do I repair my steering wheel?"
DPowers is offline   Reply With Quote
Old 07-04-2010, 02:32 PM   #13
cor86
I always use Mr. Clean Majic Erasers for interior cleaning. They work great on vinyl, plastic, and leather. Better on leather than any leather cleaner I have ever tried. If that doesn't work, I like the angle grinder method previously recommended!
cor86 is offline   Reply With Quote
Old 07-04-2010, 03:47 PM   #14
irishman999
Being serious this time... I used lacquer thinner on a rag to clean interior in a car, it was the worse interior grime i have ever witnessed! The thinner stripped it off immediately and did not hurt the plastic.
Old 07-05-2010, 12:43 AM   #15
jeff0547
jeff0547's Avatar
Talking Re: how do you get the sticky goo off the steering wheel
In the late 70's or early 80's, GM had problems with the compounds they used in steering wheels. Once they get enough U-V rays they deteriorate. Some wheels are worse than others. I had an S-10 whose wheel oozed oil from the holes in the back of the wheel. I had to throw that one out (that makes 3 I have thrown out). I always watch for wheels in the junk yard. If I find a good one, I get it.
I also have used Lacquer thinner for years. I used to be a Detailer.
jeff0547 is offline   Reply With Quote
Old 07-05-2010, 01:31 AM   #16
irishman999
You detailers know how its done! My little brother detailed at a dealership for a while and taught me everything he learned there. Do you pressure wash interiors off with them still in the car?
Old 07-05-2010, 01:04 AM   #17
jake wells
i soaked the wheel in hot water with Wesley's bleach white and no more sticky goo.you could see the nasty sh** floating to the top now its shiny black and smooth to the touch.
-thanks!
P.S. warm soapy water didn't work
Old 07-05-2010, 01:44 PM   #18
68longhorn
68longhorn's Avatar
Use black vinyl tape and wrap the whole wheel.
68longhorn is offline   Reply With Quote
Old 07-05-2010, 05:58 PM   #19
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I had that same problem with the Chevette wheel in my '37 coupe. I tried simple green, laquer thinner, brake cleaner, and carb cleaner. Everything worked at least to some extent, but some were better than others. It ALWAYS came back, though. I finally fixed it by replacing the column and wheel.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-05-2010, 06:14 PM   #20
Doug Garland
The sticky stuff is elasticizer, and as mentioned , is released by the UV rays. The early/mid '70's 4 spoke Camaro/Chevelle/Chevette wheels are notorious for the problems you mentioned with your wheel.
Doug Garland is offline   Reply With Quote
