07-05-2010, 09:13 AM | #1 |
Rear suspension setup
Hello, I have purchased the kit that includes an adjustable tracking arm for my rearend. It is a weld on but what i am wondering is should i weld it on with weight on the suspension or relaxed. It has alot of adjustment but don't want to screw it up either!! Any info would be great
Thanks Justin |
07-05-2010, 09:52 AM | #2 | |
Re: Rear suspension setup
You want to do it with the weight on the suspension, and to have the bar as parallel to the ground as possible too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-05-2010, 01:28 PM | #3 |
Set it up & determine all final positions w/full weight @ ride height. Weld it in w/the vehicle @ the best height to safely do the work.
07-05-2010, 08:04 PM | #4 |
thank you guys.... very helpful. I thought that was the way but wanted to check with the experts!! Seen some awesome rides at the good guys car show in Des Moines! very inspirational.
