Is it worth the whole rocker panel?
So I have a replacement panel ready to install.
I started poking at mine and the only section that opened up was around the original pin hole. Just a 2 X 3" patch weld in??? The rest of the rocker is solid. Seems like a bit of work for such a small patch.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 07-05-2010 at 05:37 PM. |
![]() Join Date: Apr 2000
Re: Is it worth the whole rocker panel?
to me no... i`d just weld in a patch..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Between Trucks...
For a driver I think you'd be alright with a patch. I had the same situation on mine. Dime sized hole that I patched. So far so good.
Beat it to fit, Paint it to match... ![]() |
I only like to replace what is necessary, since the factory steel is usually thicker and the bends are usually more crisp. I have replaced small sections like that before in the rockers of a Chevelle years ago which worked out well.
Here's my advise, cut the bad area out that you intend on replacing (1x3) then get one of those small pivoting mirrors and a light to look at the inner surfaces of the rocker. Make your decision on weather the patch will suffice or if you need to extend the repair further or even replace the whole rocker, based on what the mirror reveals. Rust is usually worse on the inner surfaces since the outer areas are better protected with paint and regular (sometimes) washing. Last edited by silverstreak; 07-05-2010 at 05:37 PM. |
Yeah fix it . too much work to replace for such a little hole. plus you can be done in one day
outside looked good but what a surprize lurked on the inside
once fixed you could cover the area with a nice stainless plate or threshold cover...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
![]() Join Date: May 2009
I'd replace the whole panel. The outside, under the door doesn't look too healthy to me either, from the pics.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
