Old 07-05-2010, 07:32 PM   #1
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Trim Removal Questions
Hey Y'all.............
Came across a guy who's parting out an 87 Silverado on Craigslist. Guy said I could buy the trim behind the cab, and the tailgate band with all the clips and such.. for $100,.... thing is... was talking to him on the phone.. to set-up time to check it out, and neither him or I really know how these things come off, don't wanna just start prying stuff off...fact is.. I'm new to this type of stuff.. I learn as I go.. but really am getting into sweetening my truck up, thanks to you all... any experienced advice with this... also, my truck never had the trim, and tailgate band to begin with (Custom Deluxe),.. the tail-gate band i'm curious about, is there clips behind it, that it goes onto?..... how tough is it to mount on a truck that never had it? Thanks alot in advance..... could really use the tips
- CaliDude
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 07-05-2010, 08:25 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Trim Removal Questions
The tailgate band is easy. There are like 4 bolts on the backside of the tailgate, all the clips are on the band itself. Just grab the band and bolts and look at where the holes are, or make yourself a template. Drill some holes and install.
The molding on the cab and cab corners is just about as easy. The corner moldings are held on with a nut, it is on the inside of the cab corner. You can fish your hand up in there and feel the nut fairly easy. Once you get the corner moldings off, you can literally slide the long cab molding off in either direction. It is held on with simple pressure clips.
RandyP is offline   Reply With Quote
Old 07-05-2010, 09:21 PM   #3
CaliDude76
CaliDude76's Avatar
ok cool.. I appreciate that.... as far as the "pressure clips" go.. for the straight peice under the window... do those things just screw on the cab? I've been reading about it.. and some say that their trucks had "studs' sticking out of the cab for the clips... i haven't gone down to see the truck I'm buying the trim from yet... on Fri..
I'm putting it on my truck from scratch... dont wanna buy it, if i can't put it on my truck correctly...
CaliDude76
Old 07-05-2010, 09:40 PM   #4
RandyP
RandyP's Avatar
You'll be able to get the clips off by sliding them off of their studs, it'll make sense when you see it. The clips are held on with studs, but you can use screws or rivets to install the clips on your truck.
I could be thinking of el camino moldings though, it's been 15 years since I had one apart. But I'm fairly confident in my answer.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=46
#7 is what holds the corner pieces on, has a bolt going through the cab corner with a nut on the back (inside). #4 holds the long piece on across the back. You can actually press the molding down and get the bottom edge to pop off, instead of sliding it off. I just always found it easier to slide it off, less chance of bending it but more of a chance of breaking the clips.
Old 07-05-2010, 09:53 PM   #5
CaliDude76
CaliDude76's Avatar
RandyP... YOU ROCK!!! BRO.. Now I see what your talking about.. I get the idea.. thanks a lot!!! I guess depending on the condition of the clips... I can just order em from LMC... as long as I have the trim... not bad for $100 ( cab trim and tail-band).... well, I think so anyway.. compared to the prices new (Tail-Gate band from ClassicParts is like $600!!!! geeeez!!!) All about the budget!! LOL I'll be sure and post some pics when its all done.. if all goes well. Thanks again!! Be blessed
CaliDude76
Old 07-06-2010, 05:41 AM   #6
Nukes16
Nukes16's Avatar
If your truck did not come with the trim (ie. custom deluxe) then you will not have the studs on the back of your cab to attach the clips for the molding under the back window. Likewise, you probably won't have a hole drilled through your pillar for the corner piece.
Nukes16 is offline   Reply With Quote
Old 07-06-2010, 06:05 AM   #7
baclay9
What would keep a guy from sticking all of this on with 3M tape. Assuming you don't already have the holes?
baclay9 is offline   Reply With Quote
Old 07-06-2010, 07:49 AM   #8
RandyP
RandyP's Avatar
The trim has huge lips on top and bottom, not much of a surface to put two sided tape on. You would have to build the tape up a few layers to get it to work like that really. It's very easy to put the clips on and to make a hole for the corner trim.
Old 07-06-2010, 07:53 AM   #9
bitchin85
bitchin85's Avatar
i used two rolls of 3m tape and went around the outside edge of the trim. and i swear im not crazy but mine did not have the holes going through bolting it to the cab..
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 07-06-2010, 08:05 AM   #10
RandyP
RandyP's Avatar
What a truck is supposed to have and what trucks have currently, two different things sometimes.
Old 07-06-2010, 11:38 AM   #11
CaliDude76
CaliDude76's Avatar
I suppose I better measure twice, and drill once... I'll measure the holes and spacing off of the donor truck.... can't have the trim coming out all crooked.....
CaliDude76
Old 07-07-2010, 04:59 PM   #12
Dropped84GMC
Dropped84GMC's Avatar
I haven't put trim on but I just took mine off. The little posts seemed to me to just be little rivots that had extended posts on them. To me it shouldn't be too hard to put the trim on. Just take all the measurements for the holes from the donor truck, mark out the holes , remeasure and drill the holes. I wouldn't use tape due to the backside of the molding having the lips on them and I doubt it would actually hold it how it should. Hope this helps!
1984 GMC 1500 2WD
Big plans in the making
Dropped84GMC is offline   Reply With Quote
Old 07-09-2010, 12:36 PM   #13
CaliDude76
CaliDude76's Avatar
Thanks for the tips!! I'm actually going today (Fri), to go look at the condition of the tailgate band and cab trim. Can't tell very well how it is from craigslist pictures..... anywho..., I'm planning on measuring and drilling to hold the clips on.. might as well do it right, you know?... hopefully it's in good shape.. been wanting to add those touches to my truck for a while... I'll post some pix.. soon as I get it done.
CaliDude76
Old 07-09-2010, 11:35 PM   #14
CaliDude76
CaliDude76's Avatar
I put the trim on today.... check it out.... http://67-72chevytrucks.com/vboard/s...d.php?t=411235
CaliDude76
