07-05-2010, 10:05 PM | #1 |
Transmission question?
I have a 2006 crew cab with 43,000 miles on it. It has developed a whine from torque converter lock up until 2 gear shift. Any suggestions, it is full of fluid and it is pink.
07-05-2010, 10:45 PM | #2 |
Re: Transmission question?
4L60E or 4L80E?
07-06-2010, 01:15 AM | #3 |
I'm pretty sure its a 4L60E, i looked for the paper work. I couldn't find it. But i'm pretty sure.
07-06-2010, 10:00 PM | #4 | |
Change the transmission filter & The pump to filter seal. You chould have a small leak between the filter & the filter to pump seal. The low first gear of a 4l60E will amplify the noise from the pump sucking air. |
07-06-2010, 10:15 PM | #5 |
Is the filter inside the pan like the 400's or the 350's? Thanks for the info.
07-07-2010, 09:35 AM | #6 |
