Old 02-18-2003, 02:24 AM   #1
Chevy Punk
Smile lowered longbeds
If you have pics of lwb trucks lowered about 2.5/4" then post them here please. Also can I use 1/2 ton drop spindles on my 3/4 ton or are they different? Thanks
Chevy Punk is offline   Reply With Quote
Old 02-18-2003, 02:43 AM   #2
crazy longhorn
Fabricate till you "puke"
you can use 1/2 ton dropped spindles......if you swap the lower a arms, ball joint assy, & the outer tierod ends. You will be converting to 5 lug, & also need rotors.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-18-2003, 03:02 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
here's mine it's 2/4 it's a lwb. I will try to get a side shot of it for you if you want
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 02-19-2003, 01:45 PM   #4
70 longbed
Hotrod70c10
I would be interested in that side shot.
What size tires and wheels are you running? I am curious to know what mine will look like. I hope to have the lowering kit this week, but won't have the truck back together for awhile to get a feel of how it will look.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-19-2003, 02:47 PM   #5
sixnine
Longtime Member
sixnine's Avatar
Here's a pic of mine (doctored a little). I wanted to get a feel for what the truck would look like lowered. I can't decide if I want to cut the frame and make it a shortbed or not. I don't know what the drop is because it's an altered image. Hope it gives you and idea though.
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money."
1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405
sixnine is offline   Reply With Quote
Old 02-19-2003, 02:50 PM   #6
68CST327
I personally think that longbeds look the best anyway. Especially with the 69-72 hoods. I only like shortbeds on 67's and 68's. Again though, I prefer the longbeds on those years too. But that's just me I guess.
68CST327 is offline   Reply With Quote
Old 02-19-2003, 03:01 PM   #7
70 longbed
sixnine,
Thanks. I hope that Hotrod answers, then maybe I can have someone photoshop it for me in Hugger orange. For now I am going to run 15x8 rally wheels with chrome rings and 265s. I stipped all the chrome off, and welded all the holes, but it will give me a good idea of finished product.
Keith
Old 02-19-2003, 03:09 PM   #8
crazy longhorn
Here is a looooong old booger, with a 3/5 drop, & 1 1/2" body drop with 15" wheels... http://community.webshots.com/user/hotrodhorn if you like paint, you will need to photoshop it! crazyL
Old 02-19-2003, 03:48 PM   #9
orange72
orange72's Avatar
whenever i get home i will post a pic of my truck. you can see it in my avatar. anyways it has a 2.5/2.5 all the way around. i know its not 2/4 but you sorda get the idea.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 02-19-2003, 04:17 PM   #10
Crank
Crank's Avatar
Sixnine, I'm in the same boat as you are. I want to heavily customize my truck though. It's getting an airbag suspension and 22" rims. I was wondering how damn dumb the SWB would look with 22's, ya know? I like that photoshop of your truck, but hacking it couldn't hurt either.
Brandon
Crank is offline   Reply With Quote
Old 02-19-2003, 05:39 PM   #11
Orence1
Orence1's Avatar
This is a photo shop mock-up (Thanks Carter Hickman) that is very close to 2 1/2 drop spindles, 2" drop springs and 4" drop spings in the rear that I am after.
Orence1 is offline   Reply With Quote
Old 02-19-2003, 05:51 PM   #12
Hotrod70C10
Low & Slow
sorry 70 longbed I never got back to this post I will get a side shot in a few days. I've got 15x8 rally wheels with bfg tires all around. Sorry it took so long to get back to the post.
4.5/6 drop
Old 02-19-2003, 06:32 PM   #13
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i would also like to see sice i have 3 lwb but i havent got to the drop stageyet
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 02-20-2003, 05:45 PM   #14
sixnine
Longtime Member
sixnine's Avatar
Hey Crank,
It sounds like we have the same idea. If I end up leaving it a longbed, I'll put 22"s on the rear with 20's on the front. I too think the 22's will be out of proportion on a shortbed. They should look just right on a longbed though. The larger rims on the back will help balance out the whole vehicle. Keep me posted on your ride. I'll show updates of mine when I can. Good luck.............
Old 02-20-2003, 09:19 PM   #15
Stano
Stano's Avatar
Heres 2.5"front and 4 " rear with spindles and rear springs. It sits level with same size tires on all 4 but I have 225/75's front and 285/70's rear and that gives it a rake.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 02-20-2003, 10:07 PM   #16
orange72
orange72's Avatar
heres my truck. 2.5/2.5
Old 02-20-2003, 10:12 PM   #17
lukecp
Formerly yellow72custom
lukecp's Avatar
This reminds me.....i was browsing through the JC Whitney catalog, and i found a set of little brackets that they said would either lower or rasie the ride heights on a coil spring vehicle by 2-3/4 inches. They are basicly a piece of pipe cut in half, and the go between two parts of the spring and either compress or expand it. I am skeptical that they would have some negative side effects....but it would be nice to lower my truck for $20 without swapping coil springs.........
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
