Old 07-07-2010, 12:00 AM   #1
Patriot
Question Making a G20 a 4x4???
As the title says fellas, I want to make my 1991 GMC G20 conversion van into a factory looking 4x4. I have a near mint drivetrain to put in it and I was just wondering if any of you pros have done this before??
I want to make a good Bug Out Vehicle(BOV).
The chassis I have is a SM465/205 with a Dana 44 front and 12 Bolt POSI rear. I do have a 3/4 Ton and 1 Ton drivetrain I can use(Dana 60 front, Corp 14 bolt rear and Dana 60 rear posi)
Thanks fellas for your input.
Patriot
Patriot is offline   Reply With Quote
Old 07-07-2010, 12:23 AM   #2
irishman999
irishman999's Avatar
Re: Making a G20 a 4x4???
This project sounds so bad ass, please post pictures, im sure its possible.
irishman999 is offline   Reply With Quote
Old 07-07-2010, 01:30 AM   #3
bikes&bowties
bikes&bowties's Avatar
wont the shifter on that 3 speed be 2-3 feet to far back......
i'd find a divorced np205 to go behind the transmission in there now.. fab up a crossmember (current thread in the 4x4 section) and get yours drive lines made.... just swap the rear axle with possibly some custom lift springs and then do something like a b52 kit on the front....
bikes&bowties is offline   Reply With Quote
Old 07-08-2010, 09:02 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
If you took the bend out of the shifter or even turned it 180 degrees in the case and reshaped it a little I bet it would work. I think the shifter boss would end up right about where the front edge of your seat is so probably a forward bent shifter would be needed.
You would need to find and adapt a hydraulic clutch setup for sure though.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-08-2010, 10:29 AM   #5
Chlsnk
Chlsnk's Avatar
Preparing for TEOTWAWKI?
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-08-2010, 12:01 PM   #6
willett
Another Day, Another Dollar
willett's Avatar
not to be a buzzkill, but aren't 4x4 vans notorious for bent frames?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-08-2010, 12:16 PM   #7
68 TT
68 TT's Avatar
That's after you watch too many episodes of the A-Team.
Old 07-08-2010, 07:31 PM   #8
irishman999
HAHA awesome! I always like how they use a completely different van for the jump scene, usually with the round headlights.
Old 07-08-2010, 08:48 PM   #9
Skratch
Skratch's Avatar
GM vans do not have frames they are basically unibody.
I have seen this done before, but it required massive modification to the front of the van structure as the engine cross-member and 2wd suspension mounting points are all in the way of a solid axle.
Years ago a company called Pathfinder made a kit to "bolt-in" and add either a leaf sprung or coil-over solid axle.
Leafs are very hard to do unless you want to have your mounts sticking well out in front of the van.
Coils are a bit easier, but still require massive amounts of fabrication.
Also you have to consider the differences in steering between a van and a solid axle truck.
Not to try and steer you away from this, heck I have a 94 G20 sitting in my garage that I want to do the same thing to, and I have a full 1/2t driveline sitting around to swap into it as well.
Check out Pathfinder Vans
If it ain't broke, then I haven't fixed it yet!
'86 Fiero SE 2M6 (undergoing a Northstar swap)
'87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks)
'90 3/4t 2wd Suburban (Tow Rig)
'94 3/4t 4wd G20 Van (Toasted tranny and rusted)
'96 Deville
Skratch is offline   Reply With Quote
Old 07-08-2010, 10:51 PM   #10
b454rat
I have a HP60 that came out of a Pathfinder van, was built in 85 or 86.
After reading some of the stuff in that site, I don't know if I'd want to buy anything that have...
*Small block engines and big block engines have different bell housing patterns.
*4-speed trannys can be installed if you use the rare 465 tranny top that has the shifter mounted to the rear of the shifter top. Used in the mid 80’s in 1 ton GM trucks
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-09-2010, 11:24 AM   #11
68 TT
68 TT's Avatar
I agree, blatant errors like that are a good sign they don't know jack about Chevy parts and are just making stuff up to fill space.
Old 12-28-2010, 10:10 AM   #12
turbo350
Looks like you've had several months to ponder this. Are you talking about bolting your van body to a 4wd 73-87 pick-up frame? Obviously some modding would be needed in certain areas but it sounds like the result would be worth it.
turbo350 is offline   Reply With Quote
Old 12-28-2010, 01:28 PM   #13
bmchevy1979
bmchevy1979's Avatar
I would do it if we still had are 76 Chevy g10 with a built sb350, th400 15"x10" tires in back 15"x8" in front thing had more power than my blazer sb400, th350 fun burn out machine for a thirteen year old kid but neighbors landlord hired a tow company to take some cars off his property and they took it off of are property with the cars they were there for and it was never seen again.
imagine this with slot mags and lowered it would be the exact van
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-28-2010, 01:35 PM   #14
bmchevy1979
But this would be cool you should definitely do this
<Brandon>
Old 12-28-2010, 04:36 PM   #15
Squareforceone
Squareforceone's Avatar
That is a sick van! but did you ever get any money or anything for your van being basically stolen?
Squareforceone is offline   Reply With Quote
Old 12-29-2010, 10:24 AM   #16
bmchevy1979
It was my dads van but we never did get any money for it we never could get a hold of the landlord. he was avoiding us that has been 4 years now and have not seen a glimpse of him at all new people moved in and we never saw him once
<Brandon>
Old 12-29-2010, 12:43 PM   #17
Squareforceone
Well that is b.s. if it had been my van i would of done everything to get a hold of landlord (im sure you did) and then filled it as being stolen
Old 12-29-2010, 01:24 PM   #18
manimal
manimal's Avatar
You could always fab-up a Ford style radius arm from suspension.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-29-2010, 09:30 PM   #19
str8axle55
There is one for sale on CL in my area, been for sale for a while. I think it`d be a cool idea, weekend camper, beach cruiser.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 01-06-2011, 10:57 PM   #20
sailed2japan
Jonny
sailed2japan's Avatar
I just spotted this while looking for parts on craigslist. If you're interested in making the drive down I can go check it out and take pics. looks like it would save you alot of fab work and give you a rust free body.
http://austin.craigslist.org/pts/2128123291.html
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 01-06-2011, 10:58 PM   #21
sailed2japan
Jonny
Opps just noticed that it says the body is trash....Still a good chassis!
-AEC Hundley USNR
Old 06-10-2014, 01:59 PM   #22
Jason Sowell
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Jason Sowell is offline   Reply With Quote
Old 06-10-2014, 09:05 PM   #23
motornut
78K & 79C Jimmys
motornut's Avatar
saw this the other day
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-21-2017, 07:37 PM   #24
Johnnyboy55
Hi there. I am new to the forum so bear with the poor computer skills. This is my 1986 g20 4x4 conversion, did it the hard way[myself] but worth it
Johnnyboy55 is offline   Reply With Quote
Old 08-13-2017, 09:36 PM   #25
Dlatimer
Hi I sure like your van I have one I am about to start on its a 1983 GMC shorty
Dlatimer is offline   Reply With Quote
