07-10-2010, 01:48 PM | #1 |
bedliner fitment???????
anyone with a 73-87 that has installed a later model bedliner in it wondering witch would be closest to fit
07-10-2010, 03:19 PM | #2 |
6.0 powered square
Re: bedliner fitment???????
A rubber mat or the plastic liner
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-10-2010, 07:50 PM | #3 |
Not sure if you are asking to install a bedliner for a later model truck that would intentionally not match your bed? If you are asking for a recommendation for a bedliner, I would go with a bedrug. Covers the gap between the tailgate and the bed and cushions the load. Downside is it leaves tiny bits of wood chips in the fibers when you haul plywood or osb, and it does hold the moisture for a while after it rains - just like wet carpet.
