07-12-2010, 06:36 PM | #1 |
Stupid Question?
Perhaps this subject has been discussed in the past. Or perhaps I am just plain stupid..... But what are the two short, flexible, approx 1 1/2 dia. "tubes" that exit the cab of my '64 SWB Fenderside and head towards the rear of the cab just below the fuel tank?
07-12-2010, 07:05 PM | #2 |
Senior Enthusiast
Re: Stupid Question?
I'm not familiar with what you are describing. Can you post a photo?
07-12-2010, 09:45 PM | #3 |
Enjoy your truck
His and hers p*ss'er tubes?
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
07-12-2010, 10:41 PM | #4 |
Check The Champ, Demonstrator
Saw something similar on a camper conversion with dual saddle tanks hanging off the frame. Used the regular filler neck but diverted the fuel to each tank. There was no tank in the cab.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 07-12-2010 at 10:42 PM. |
07-16-2010, 03:08 PM | #5 |
Here are two images of the flexible tubes exiting the bottom of my fenderside cab just below each end of the fuel tank. Any ideas about what these tubes are for?
07-16-2010, 04:49 PM | #6 |
Are they flush with the floor inside of the cab or do they go up higher than the floor? Do they have a markings, like something was attached to them inside the cab?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-16-2010, 05:12 PM | #7 |
Senior Enthusiast
They certainly have the appearance of being flexible exhaust tubing, but can't imagine the intended purpose unless it was some type of owner designed drain. Doesn't look like the type of tubing that would be used to carry fuel to a remote tank. Judging by the design of the clamp and condition of the tubes they have been on there a long time. It will be interesting to see if you have the only truck on the planet with these tubes, or if they are left over from some accessory or factory option.
07-16-2010, 05:29 PM | #8 |
They had a ice chest in the box of the truck. #1 tube was attached to the output of a fan that was plumbed in the ice. The #2 hose returned the warmed up air from the #1 hose, thus cooling the cab. Somewhat like how a Thermador worked but on steroids. Unlike the Cool Pack that hung from the dash, referred to as Crotch Air, the system was known as Butt Air. GM Accessories part # 3866676. The icebox was color coded to the main body color of the truck. Coleman was the supplier of the ice chests.
Conspiracy Theory and Urban Legend!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 07-16-2010 at 05:47 PM. |
07-16-2010, 05:52 PM | #9 |
Dual exhaust ran down the outside of the frame. Two boxed in sections surrounded the exhaust tubes with a perforated inlet. The tubes in the pictures were connected to the outlet of the boxes that allowed the warmed air to supplement the standard heater?
Theory II Come on, this is turning into a contest!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 07-16-2010 at 05:57 PM. |
07-16-2010, 06:10 PM | #10 |
Aerotruk, I challenge your theories on this particular truck, although Ive heard many a tale about Butt Air!
I believe if Andice does a Vin/Title search he will find his truck was at some point owned by a Mr. Marin or a Mr. Chong. These flex tubes were attached to a 'burn box' that sat atop the exhaust Y pipe. Theres a secret compartment in the bed floor, by where you could fill it with local greenery and hotbox on the go - Hey, man you gonna eat that hot dog? |
07-20-2010, 08:33 PM | #11 | |
All silliness aside, perhaps it was merely a way to get air flow to circulate through the dash / kick panel vents and then out through the vent tubes? The working man's Astro Ventilation? Last edited by lakeroadster; 07-20-2010 at 08:35 PM. |
07-20-2010, 09:48 PM | #12 | |
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
07-22-2010, 12:47 AM | #13 | |
60-66 Nut
This sounds to me like the most sensible function of the tubes.....seems like a good idea, particularily in Texas where it's hot.
07-22-2010, 03:59 PM | #14 |
But Texan's don't drink & drive....
07-22-2010, 09:14 PM | #15 |
Scoti,
It's Astro Ventilation, not Houston Astros Inebriation. |
07-22-2010, 11:12 PM | #16 |
A good possibility. I know with my truck, the kick panel vents flow alot better with a window open. Also, they could be to vent the cab to make the doors close easier. I have to slam the door to close mine but if I crack a window, they close rather easily.
07-16-2010, 06:12 PM | #17 |
Lmao!
07-16-2010, 09:37 PM | #18 |
The square nuts on both sides of the support are for the rear seat tracks, so the tubing enters the cab between the seat at the back rest just in front of the fuel tank and the door.
07-16-2010, 09:45 PM | #19 |
These tubes are not flush with the cab floor. There is an approx 1/4 inch lip.
07-16-2010, 09:49 PM | #20 |
Has a full bench seat?
07-16-2010, 10:11 PM | #21 |
Original full bench seat with the original two-toned vinyl.
07-16-2010, 10:52 PM | #22 |
The guys at the autoparts store all agree, that tubing would not be good for a liquid. So the thought was there was a camper unit in the box and they used the tubing as conduit for air conditioning! Heating anything would have been easier with rubber hose and t's. Is the cab original to the frame?
07-20-2010, 02:53 PM | #23 |
Take a pic from inside the cab if you can. This "stupid" question sure has gotten a lot of interest, maybe not so stupid after all.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr Last edited by Malibob; 07-20-2010 at 02:54 PM. |
07-20-2010, 05:06 PM | #24 |
All the years I've been looking at trucks, different sizes and models, never seen this before! This is a great puzzle. Shall we assume this is a southern truck?
07-20-2010, 10:25 PM | #25 |
Quote from Barracuda Magazine
"In front of the passenger's seat is one of the Kenford's more intriguing features -- a brass-topped tube with "Tube Le Dump" engraved on it. This tube is a beer can ejector designed by Dutch for a '66 Olds Toronado he used to drive. The tube leads to the road below, so Von Dutch could get rid of empties without having to toss them out the window while driving." http://www.barracudamagazine.com/vondutch.htm
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 07-21-2010 at 06:55 AM. |
