![]() Join Date: Apr 2010
help with rims
ok so how can rims be 5 lug universal, i have seen some on cl that i like, the seller says they are 5 lug universal, but how universal can rims be givin the diff 5 bolt patterns, thanks for your help
6.0 powered square
Re: help with rims
the wheels have extra lug holes for the different bolt patterns
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: help with rims
Older rims have oblonged holes and the wheel nuts center them so they fit most vehicles
Re: help with rims
do u run into any problems using universal rims, any concerns i should have when thinking about these rims?
Re: help with rims
Many of the 'universal' rims fit either 4 1/2" or 4 3/4", but NOT the 5" truck pattern. Check them with the correct lugs before you buy. Sunce the lugs go into the slots, if the stud is close to the end of the slot it may not work.
The lugs go thru the rim into the slots to center the wheel, and the top of the lug clamps a washer down on the wheel to hold it on. Make sure that you can get the correct lug length and pattern. If the lig bottoms on the hub/rotor/drum it will not clamp the wheel and it will eat the rims up quickly. If the lug is too short it will not have much contact patch in the slot and will want to chew up the rim. Do NOT put them on the rear of a heavy big block vehicle with sticky tires. The local contact patch at the lugs tends to crack the wheels if you ever make it hook. Oh, and never try to do hard core cornering with them. They make nice pretty wheels for cruising. We used many a set in the 70's on our low powered cruisers. But they are a big no-no for any serious power or racing.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
