![]() Join Date: Nov 2002
We're yanking the cab off of an old '67 and while the rear mounting bolts came out o.k., the front bolts are just spinning with the nut. Can I just hit them with a sawzall and get the leftover parts out after I get it yanked?
Thanks. |
Re: Front cab mount question
dont yank it be gentle with the 67
Have you tried holding the head of the bolt?
Some of of the bolts were welded in but I believe not all. The weld can break but I have been able to grind the bolts enough to get a socket on them. If the bolts are good they can be worth saving as they are a 9/16" thread. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
The rear nuts are welded in, but the front have loose nuts located under the carpet.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
