Old 07-13-2010, 11:14 AM   #1
edpdx
new switch for AUX tank... still no gas?
I replaced the switch cause I was not getting any fuel out of my Driver's side AUX tank- It has worked like a champ since I got the dealer installed option in 74 (its a 73 C20).
I disconnected the line at the switch and blew into the tank- the hose is clear as I hear it gurgling mightily. I am guessing it is a bad pick-up in the tank or clogged sock filter.
Is this a job better suited to a shop? I have fuel in the tank. I imagine I can drain it into sever 5 gallon gas can I have; but looking at the way these were installed, it looks like a nightmare (a rusty nightmare) to get the hardware holding the straps out.
What would a new tank INSTALLED run?
edpdx is offline   Reply With Quote
Old 07-13-2010, 11:50 AM   #2
Chlsnk
Chlsnk's Avatar
Re: new switch for AUX tank... still no gas?
Have you checked the ground straps on the tanks?
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-13-2010, 12:25 PM   #3
edpdx
I am washing my cougar in the Driveway, I'm going to check the ground next. Thanks, and I'll update.
Old 07-13-2010, 01:28 PM   #4
Don SC
Don SC's Avatar
edpdx- when you toggle the switch on the dash can you hear the motorized switching valve operate under the truck? If the valve is not working you will only get gas to flow from one tank.
Don SC is offline   Reply With Quote
Old 07-13-2010, 10:07 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
^^^ This is my guess too.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-13-2010, 10:30 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I would bet Bobs money it's the switching valve too!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 07-13-2010, 10:48 PM   #7
glock35ipsc
Stay outta my pockets!
Bob
