Old 07-17-2010, 10:04 PM   #1
watindes
watindes's Avatar
Rear drop question
Ok, I want to lower my rear end by two inches and I can't find a reasonable drop hanger so my question is where I can find a flip kit, I will remove my shackles and just use a no notch kit. Or can I remove a few leaf springs ( I have removed the overload already but it has hangers on it now, I need a 2/4 drop and have hangers now. Also what springs should I get and are there any other chevy trucks I can get off the shelves that would fit my truck?
A source for a cheap (but good) flip kit or leaf removal and good shock source are my questions,
Jesse
Pic below is the truck as it sits now
The ultimate swear!
Your mother is a *beep beep beep*ing*beep*lorem ipsum*beep beep beep*admiumvenium*beep beep beep beep*turolagulio*beep beep beep beep beep beep beep beep* hippopotamus*beep beep beep beep beep beep*beep beep beep* Daniel Radcliffe *beep beep beep beep* with a bucket of *beep beep beep beep* in a castle far away where no one can hear you *beep beep beep beep beep beep* soup *beep beep beep* with a bucket of *beep beep* Mickey Mouse *beep beep* with a stick of dinomite *beeeeeepppp* magical *beep beep beep beep* ALAKAZAM!
watindes is offline   Reply With Quote
Old 07-17-2010, 10:58 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rear drop question
If you want to do this on the cheap, it will require some effort to accomplish. If you drill the rivets from the stock hanger, you can raise it up almost two inches on the frame. You make need to chop the upper ends of the brackets off to clear. Drill new holes in the bracket and bolt it down.
Note that this should be done in conjunction with a lowering shackle to keep the pinion angle on plane.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-17-2010, 11:23 PM   #3
watindes
watindes's Avatar
If I did it that way, when I remove the bracket should I measure 2" from the bottom hole. Its a great idea and would save a bunch of cash, can you give me (or a link) a how-to on what to do to mod the hanger?????
Jesse
The ultimate swear!
