Inline 6 Harmonic Balancer removal??
I've got the removal tool, but I can't find a retainer nut or bolt holding the damn thing on, is there one? I don't wanna start pulling and mess anything up but I need to know. Any help quickly would be great!
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 07-18-2010 at 03:17 PM. |
Re: Inline 6 Harmonic Balancer removal??
Many of these early engines came with press fit balancers the cranks were often later tapped for a bolt when rebuilt. Just check carefully before forcing it off.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Active Member
![]() Join Date: Jul 2007
That's correct... My 68 only had an indentation and when I had the crank out for rework I had the machine shop drill and tap for a crank bolt. Easier to reinstall that way.
If your crank is threaded, don't try using the stock bolt to pull the balancer on. It's a good way to strip the threads. Instead, use a piece of allthread and screw it into the crank by hand as far as it will go. Then use a nut and washer on the allthread to pull the balancer on. It helps if you grease the threads and both sides of the washer.
Ray Last edited by raycow; 07-20-2010 at 01:27 AM. |
Auto zone offers the correct tool for free rental.......just make sure the threads on the tool are not messed up
