07-18-2010, 10:22 PM | #1 |
63 rebuild
Whats up guys, I've been on this sight awhile checking out things, and decided to show you my build. This is a 1963 Chevy pickup i've had since 1985 when i was 16. It started out with a 460 ford motor in it, it had to go. I put a 350 in 3 years later and had it painted, drove it till 1992 and parked it. Been setting ever since. I decided to tear it down and give it a new life. http://67-72chevytrucks.com/vboard/a...1&d=1279506104
07-18-2010, 10:28 PM | #2 |
Re: 63 rebuild
07-19-2010, 07:23 AM | #3 |
UCA63
Re: 63 rebuild
Lookin' good boat
Love the mother-in-law seat LOL T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
07-19-2010, 07:02 PM | #4 |
Re: 63 rebuild
more pic
07-19-2010, 07:12 PM | #5 |
Re: 63 rebuild
Well down to the frame ,so this is where it starts
07-19-2010, 11:12 PM | #6 |
Re: 63 rebuild
A lot of work went into these pic, cleaning, scraping, grinding, sand blasting,then primer.now its clean enough to work with.
07-20-2010, 01:20 AM | #7 |
60-66 Nut
Re: 63 rebuild
That's cool that you've hung on to this truck this long....was it your first vehicle? Looks like it was pretty nice before you tore it apart. What's the basic plan this time around? Your truck is the ideal truck IMO.....A '63 Custom Cab, big back window, short fleetside
09-26-2010, 09:13 AM | #8 |
UCA63
Re: 63 rebuild
That's looking great Boat
Is that the original trans x member,just moved rearward?(sans lower supports) If so,what kind of E brake set up did you have? I'm at about the same stage with mine(also a '63)and need to make a decision soon on what I'm going to use.I'll be running a TH 350. Thanks,T
09-26-2010, 12:46 PM | #9 |
Re: 63 rebuild
no its not the original trans member .when i bought the truck it had a 460 ford engine in it ,when i dropped the 350 in i used the same cross member just moved it around a little works fine, don,t know what it came out of . as far as e-brakes i never had any cables ran anywhere so i need to figure that one out.
09-26-2010, 12:49 PM | #10 |
Re: 63 rebuild
more pic
09-26-2010, 12:52 PM | #11 |
Re: 63 rebuild
rear end
09-26-2010, 02:51 PM | #12 |
Resistance is Futile
Re: 63 rebuild
.......lookin' sweet boat!!! Sure nice to work on them with all the easy access. Cant wait to see more progress.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
09-26-2010, 10:33 PM | #13 |
Re: 63 rebuild
Thats awesome, Boat! Subscribed for sure!
09-27-2010, 01:00 AM | #14 |
Re: 63 rebuild
sandblasted and painted some parts
09-27-2010, 01:02 AM | #15 |
Re: 63 rebuild
the new blasting box
09-27-2010, 01:11 AM | #16 |
Re: 63 rebuild
got my new power steering box ,just waiting on the conversion kit from classic parts
09-27-2010, 07:29 AM | #17 |
UCA63
Re: 63 rebuild
Your working fast Boat,looking good
That does look like the relocated original Not sure if the shortbeds were setup the same or not,but my longbed has a separate crossmember for the E brake(behind the trans member)
09-30-2010, 11:30 AM | #18 |
Re: 63 rebuild
I really like your use of a engine hoist and wood frame to remove the cab. Great idea which I will steal when it comes time for my project.
Brian |
09-30-2010, 04:09 PM | #19 |
Re: 63 rebuild
I seen this engine hoist design on this sight but added two extra bars, works great.
10-06-2010, 10:20 PM | #20 |
Easy Does It
Re: 63 rebuild
did you use the stock frame mount for the panhard bar?
10-07-2010, 12:13 AM | #21 |
Re: 63 rebuild
10-07-2010, 12:37 AM | #22 |
Re: 63 rebuild
been working on motor and trans
10-11-2010, 10:25 AM | #23 |
UCA63
Re: 63 rebuild
Looking sweet boat
T
11-28-2010, 12:13 AM | #24 |
Re: 63 rebuild
got brake lines on
11-28-2010, 12:18 AM | #25 |
Re: 63 rebuild
more pic
