Old 07-21-2010, 08:08 PM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
header gasket?
i believe i have an exhuast leak from the header gasket so iv been lookinh on the web and have found several types i was wondering what you guys would recomend to use or what your using thanx
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 07-21-2010, 08:15 PM   #2
benoit454
Chris
benoit454's Avatar
Re: header gasket?
stock exhaust manifold gaskets if you are talking about the ones where the header bolts to the block, if not then aluminum or copper on the collectors since they are reuseable. They make the same ones for the block side but I found exhaust manifold gasket to work great, as long as they are the aluminum perferated looking ones.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-21-2010, 08:17 PM   #3
81ratrodc10
house of chevy's
Re: header gasket?
ya i actually am going to replace both but i was talking about the ones on the block
1987 m1028 cucv d30
2001 chevy s10
Old 07-21-2010, 08:35 PM   #4
85burb
85burb's Avatar
Re: header gasket?
I have the dead soft ones they sell at pepboys. After you retighten them for about 3 weeks they are perfict. Have not messed with them in over a year. blew 3 sets out of the regular kind. The dead soft are like 50 bucks but 3 sets of the reg are like 60.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 07-21-2010, 08:41 PM   #5
81ratrodc10
house of chevy's
Re: header gasket?
we dont have a pep boys around here and advanced auto has been out for weeks so started looking online am going to try another place tommarrow but wanted to know what you guys were runin
1987 m1028 cucv d30
2001 chevy s10
Old 07-21-2010, 08:48 PM   #6
85burb
85burb's Avatar
Re: header gasket?
autozone has some too. That is the only places i go due to location.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-21-2010, 09:26 PM   #7
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: header gasket?
ok here is the trick, if you have aftermarket headers you can use the regular mr. gasket sets but use 2 on each side, sinch them down good and your problems should be good.
staggerd86c-10 is offline   Reply With Quote
Old 07-24-2010, 05:02 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: header gasket?
X2 it works
copper ones suck! i got a set and they leaked like hell
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-21-2010, 09:34 PM   #9
benoit454
Chris
benoit454's Avatar
Re: header gasket?
advance auto has an online store like autozone that you can pay shipping to your house r have it from the website to the store for pickup and avoid shipping, or at least they did, I know autozone still does. Then there's summit, jegs, and amazon.
I have the percy's dead soft alum. collectors, or seal 4 good they call em, comes with bolts and all I tightened them once and that was it, no leaks and no retorque.
Chris
GIT R DONE!!!!!!
Old 07-21-2010, 09:34 PM   #10
82chevy350
82chevy350's Avatar
Re: header gasket?
just get percys soft alluminum gaskets like 30 bucks from autozone no more worries
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 07-24-2010, 01:08 PM   #11
HOGDADDY
HOGDADDY's Avatar
Re: header gasket?
The gaskets that come with Thorly headers have never leaked not sure what kind they are though.
HOGDADDY is offline   Reply With Quote
Old 07-24-2010, 02:33 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: header gasket?
X2. havnt touched mine in a year
Old 07-24-2010, 02:04 PM   #13
texasfunk
texasfunk's Avatar
Re: header gasket?
i've always just used stock manifold gaskets, neve ad a prop! and you dont have to take the header all the way to put them on, or replace them just in case something does happen.
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 07-24-2010, 06:58 PM   #14
GRX
GRX's Avatar
Re: header gasket?
In my experience the soft copper & aluminum gaskets work very well provided your headers' gasket area are flat. As I've seen with some of the cheaper headers the tube ends are simply sawed off = rough edge. In this case a pass on a belt sander does wonders.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-24-2010, 08:34 PM   #15
82chevy350
82chevy350's Avatar
Re: header gasket?
just get the dead soft aluminum ones and be done with it you can reuse them as many times as needed
(Hot Rod)
(Daily Driver)
(Toy)
Old 07-25-2010, 07:03 PM   #16
Alex1
Alex1's Avatar
Re: header gasket?
RTV sealer works too.
Alex1 is offline   Reply With Quote
Old 07-26-2010, 07:17 PM   #17
81ratrodc10
house of chevy's
Re: header gasket?
thanx guys for all the sugs i was away all weekend but maybe this week i can go get some
1987 m1028 cucv d30
2001 chevy s10
