Old 07-21-2010, 10:36 PM   #1
Rat Bastid
Rat Bastid's Avatar
ignition switch removal problems
ok guys this should be simple right,put key in ignition ,turn to on,put paper clip into little hole ,push in,turn key to accessory and viola.......nothing......over and over i tried,and got nothing but upset.......i need to remove this in order to remove the bezal correct......im stumped,am i doing something wrong here? helppp
Rat Bastid is offline   Reply With Quote
Old 07-21-2010, 11:22 PM   #2
hotrod100
hotrod100's Avatar
Re: ignition switch removal problems
With it in the off position push the paper clip in the hole then turn to acc. Don't turn it to the on position. You may have to wiggle the lock cylinder with the key to get it to pop loose. And yes you need to remove it to remove the bezel.
My build thread.
hotrod100 is offline   Reply With Quote
Old 07-21-2010, 11:29 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Yeah it takes some time, dont get frustrated you are doing it right...
John
1999 Toyota Tacoma 4x4
Old 07-22-2010, 12:17 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
67's and some 68's don't have an accessory position. Just put the key in the ignition and "gently" turn it as far to the left as it will go. Insert a straightened paper clip in the hole (the large ones work best) and push the release pin down (go easy here, it doesn't take much pressure at all) and turn the cylinder to the left a little more. As you turn the cylinder you have to remove the paper clip or it will bind in the hole. The cylinder should pull out. You should not have to force anything.
LockDoc
Leon
Old 03-05-2011, 05:17 PM   #5
67Dad
67 c10: I put a tip cleaner in the spring hole by the key. It loosened and the decorative bezel appeared to unscrew (or just slide?), but it only opened up about 1/4 - 1/2 inch or so and won't go any further. Wires are off back, cylinder is now "loose" in the dashboard, but bezel keeps it from coming out completely. Any ideas or trick short of destroying it?
Thanks.
Mark
Mark
57 Austin Healey 3000 (sold many moons ago, unfortunately)
67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition
93 C4 Corvette (mostly done, son's)
67Dad is offline   Reply With Quote
Old 03-05-2011, 11:39 PM   #6
LockDoc
LockDoc's Avatar
Thanks.
Mark
If you follow my instructions in the post above yours it should come apart. The bezel won't screw off until you take the lock cylinder out. I think you are confusing the switch assembly with the cylinder. The cylinder is the center part that the key goes into. If you don't have that out yet screw the bezel back on the switch until you get the cylinder out. Be careful not to cross thread the bezel, the threads are really fine on it. Here is a picture with the parts labeled.
LockDoc
Leon
Old 03-06-2011, 12:08 AM   #7
67Dad
Got it! Without breaking!
MANY thanks for the help and pics.
Mark
Mark
Old 03-06-2011, 01:47 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
Any way to do this without having the original key?
Old 03-06-2011, 01:53 AM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
Sawzall from behind the dash was how i did the last one...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-06-2011, 01:54 AM   #10
LockDoc
LockDoc's Avatar
The code number should be stamped on the door lock cylinder, (see pic below) sometimes one, sometimes both. The only time I have found one that didn't have the code stamped on it is when the lock had been replaced with a new one. Check the passenger door first. Generally the lock case will have to be cleaned very well to be able to see the code number. A small wire brush, steel wool, scotch bright, or sandpaper usually works well for this. I do not recommend a wire wheel because it will completely remove the code number if it is stamped lightly. The code number is always stamped into the lock case, never cast into it. Most locksmiths can cut a key from this code number. Home centers and hardware stores will not be able to do this. If the locks are original to the truck or were all replaced at the same time the key made from the code number on the door lock should fit the ignition switch & usually the glove box too (but not always).
LockDoc
Leon
Old 03-20-2011, 02:23 PM   #11
71gmcburb
71gmcburb's Avatar
I had to do this to my burb. the PO lost the keys and when he sold it to me he had a replacement hanging below the dash by the wires!
I drilled out the original to get the bezal off and then I installed the replacement switch in the original location with the original bezal
no sawzall needed
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 03-06-2011, 01:56 AM   #12
todd99
When mine broke after hours of frustration I gave up on replacing it. I went to radioshack and built a new ignition.
1971 C20 Longhorn Custom Camper
todd99 is offline   Reply With Quote
Old 03-06-2011, 11:25 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
I like the sawzall idea
Old 03-19-2011, 11:45 PM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
Has anyone had the ignition and doors setup to use the same key?
Rich
1972 K5 Blazer CST Click HERE
Old 03-20-2011, 12:48 AM   #15
VA72C10
VA72C10
VA72C10's Avatar
yes, a locksmith could re-key them or you can buy complete kits with ignition, door locks, and even a glovebox door lock all keyed the same.
Old 03-20-2011, 02:31 AM   #16
long69
mine are keyed alike, i had to get new locks for the doors and when i did i had them key'd the same as the ignition. as i recall finding a cheap locksmith was a chore but i found one at a fair price. i think i paid 30 bucks. it took 15 min so i think 30 was fair. shoot now that i think about i wonder if it would have be cheaper to just have changed the ignition key to match the new door locks
long69 is offline   Reply With Quote
Old 03-20-2011, 01:59 PM   #17
LockDoc
LockDoc's Avatar
Yes, it would have been cheaper to re-key the ignition lock cylinder. To re-key the door locks you have to remove the stainless cover from the front of the lock which usually means replacing the cover. Plus you have to re-key two locks when you do the doors.
Another thing to consider for anyone else thinking about doing this is to make sure that the key that you are going to use physically fits into the lock you are going to have re-keyed. There are four different keyways and key blanks for the '67-'72 chevy & GMC trucks.
Also, to mirror what Andy said all '67-'72 GM trucks came from the factory with the doors and ignition keyed the same...
LockDoc
Leon
Old 03-20-2011, 08:29 AM   #18
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
all 67 to 72 trucks came from the factory like this
Old 03-20-2011, 04:37 PM   #19
mightymouse
mightymouse's Avatar
it works i just got mine off too thanks i was also stumped on this
mightymouse is offline   Reply With Quote
