Old 07-22-2010, 09:12 PM   #1
camjck89
camjck89's Avatar
power steering
hey guys i got a power steering setup from my step brothers 3/4 ton 72 and i was wondering if theres an easy way to swap it to my 2wd 72 1/2 ton?
Also i have the power brakes from his 3/4 ton as well, and pretty much have the same question as above . just a quick rundown on what im in for (if much).
camjck89 is offline   Reply With Quote
Old 07-22-2010, 11:08 PM   #2
camjck89
camjck89's Avatar
Re: power steering
no one???
Old 07-22-2010, 11:47 PM   #3
67ss&99ss
Andy
Re: power steering
did you get the crankshaft pulley for the power steering? Does the pump have all of the mounting brackets? did you get all of the bolts for mounting it to the block? I just converted my half ton to power steering and power brakes. its a simple swap. if you need a new rag joint, you'll have to order it online from one of the vendors. I haven't seen the correct sized one in the parts stores, its too small. It will take a few hours to do the steering but it shouldn't take much longer than 30 mins to do the power brakes. You can leave your existing master cylinder hooked up and just bend the lines so that it bolts to the booster. They are long enough.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 07-23-2010, 12:07 AM   #4
camjck89
camjck89's Avatar
Re: power steering
well i have the crankshaft pulley(never been disconnected from the steering box) not definate on the bracket(s) negative on the bolts. the brakes just have the shaft coming out the back of the booster i dont have the rest of the pedal off the 3/4 ton. i also dont know if theres anything to do to the replacement booster and cylinder to not have to bleed the brakes(dont know if it needs to be bench blead)
72 lwb farm truck 86k o.g. miles.
350/th350
89 toyota 3" drop 22r 4spd 2wd
