dropped69
Fender help
Hi i'm putting my fender back on and I just can't remember which bolts go where I have so many bolts from other stuff, can somebody please post a picture or tell me which bolts go where, and how many bolts I should have, and a certain order to put them in because I tried to put it on and man it sure is a pain to get all the holes to line up, can someone please help me out..maybe a certain bolt order would help it line up evenly..i don't know I just want my truck going again!!
which fender are you putting on
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
This is the way we do it.
Tape card board onto leading edge of door and rocker. Hang fender on rear bolts, (3/8-16 with large flat washers) two on top, one on bottom, leave loose. It helps to have someone hold the front. We leave the liner out until the fender is installed. Start bolts from fender to radiator support, leave loose Install triangular corner brace to fender and support, leave loose At this stage we measure for squareness and opening for hood, adjust as necessary Check rear for alignment and measure hood opening, shim top or bottom bolts to match door, set gap before tightening bolts Tighten bolts from fender to support and remeasure It is an iterative process, so you may have to go back and readjust. Once you get the hood on, readjustment may be necessary to get the gaps right. Install liner. Jim Last edited by JimKshortstep4x4; 02-20-2003 at 02:45 PM. |
dropped69
it's the passenger's side fender...thanks lots jim, how do you put the radiator support on now? once I have the passenger side, should i put the radiator support now? then put on the driver side fender after that? or...also which order should I put bolts in for the radiator support, and those two that are on each part of the frame with the rubber things? how are those supposed to go back on? thanks lots!
Sorry!
I thought you only had one fender off. The saddle should go on first, (radiator support). I try to center the support to the frame. Leave the support mounts loose and check for front to rear level of the fender by doing a trial fit. If the front is high you will have to shim the cab. If it is low then shimming of the mounts is needed. I usually rough position the support square to the cab, front to rear and then check the "x" dimension. After that hang the fender per what I posted before. It can be a little painful, but be patient, it will work out. On the radiator support rubber mounts, bolt those up first, loosely. Jim |
when i assembled mine i put the whole front end together minus the hood and then mounted it it was just place it and bolt it
Rad Support, Tubs, Fender 's Hood Cowel. Leave everything loose . To tighten the tubs start at the top bolt then go down one at a time from Left to right or vis versa.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
