07-26-2010, 05:24 AM | #1 |
temp gauge/ overflow issue
Here is the deal, I work swing shift and go to work around 230pm and leave work at midnight.
On the way to work truck runs fine temp gauge (auto meter sport comp) stays at 180. on the way home the truck runs fine but about 5-10 mins into the 20 min drive home the gauge pegs at 250 very fast, then drops down to 200 then a little slower pegs again then drops to 180 for the rest of the way home. I do loose coolant about a 1/4 of a gallon or so that spills out. The probe for the temp gauge is in-between the 6 and 8 cly in the head. Should I move it to the front of the intake mani? Here is what I have tried. New thermostat and housing. ( the old one was pointing straight up and was off of a tbi motor) New 16psi Radiator cap. Truck has a 87 Trans am Radiator in it. should it be higher than that?? I tried burping the system with the front of the truck pointed uphill with the rad cap off and running. Also the truck has no heater and all the holes have been plugged Any ideas?? Thanks
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby Last edited by Wilson_; 07-26-2010 at 05:25 AM. |
07-26-2010, 06:45 AM | #2 |
"THE GREEN GOBLIN"
Re: temp gauge/ overflow issue
I had an issue simular to that it would run fine in normal stop n go traffic and in short distinces then temp would climb up on longer drives or up hill. But then go down to normal when I slow down for traffic or come to a complete stop. Had it check and my Radiator was plugged. Do you hit traffic on your way to work, Then on the way home just drive higway speed with no traffic maybe it could be that? It is weird though hope you get it fixed soon
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
07-26-2010, 07:26 AM | #3 |
what type of fan setup are you running??
has this system been run without problems for a longer period of time? if it's a junkyard radiator was it ever cleaned and tested prior to use?
07-26-2010, 09:51 AM | #4 |
Active Member
Maybe going downhill to work and uphill back?
Seriously, drain all the fluid and refill with clean 50% water and 50% anti freeze or even 60% water 40% coolant. Then install an overflow tube. You can make you a cheap one out of pvc hot water tubing (I used black from Lowes) Cap it at both ends and glue just the bottom one on. The top should fit snug but can be removed if you need to. Drill a hole just large enough to insert the radiator overflow hose in it almost to the bottom. Place it in any convenient place and use nylon ties or large clamps to secure it. In my 68 it fits betwen grill and radiator support. Solved my overheating problems and kept me from losing coolant. I've had it for about 2 years without any problems even in this Texas heat... |
07-27-2010, 03:29 AM | #5 | |||
I will try and get a video tonight
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
07-27-2010, 05:19 AM | #6 |
they did not come with overflo tanks in 67
do you have a fan shroud to move air effectivly thru your radiator for cooling?? with that year radiator, if it has the stock 80's radiator cap you need to have a closed system.. radiator caps for the earlier cooling systems in 67 are made to function differently
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 07-27-2010 at 07:56 AM. |
07-27-2010, 04:05 PM | #7 | |
07-27-2010, 05:57 PM | #8 |
I got a new cap, It looks pretty much the same as the other one but we will see how it works.
I will let you guys know tonight.
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby Last edited by Wilson_; 07-27-2010 at 05:57 PM. |
07-27-2010, 08:06 PM | #9 |
Who's got steelies?
You can make yourself a pretty nice "factory" looking setup with an extra washer bottle and bracket:
As long as you have the tube that attaches to the underside of the cap, it will suck water back in.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 07-27-2010 at 08:15 PM. Reason: resize pic |
07-27-2010, 11:47 PM | #10 |
could it have air pockets in the radiator? thats what happened in my eclipse
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-28-2010, 10:40 AM | #11 |
as stated earlier I would put a shroud on it /clean out the rad/ get the proper cap/overflow bottle and be done with it. (the only time my truck got hot it didn't have a shroud) so I learned from this and will never run without it again best of luck. cheers, Pat
07-28-2010, 07:55 PM | #12 |
Make sure that neither of the hoses is sucking shut, soft hose or no internal spring. Recently had this happen on a 70 440 Cuda, only ran hot on the highway.
Bill |
