07-28-2010, 01:06 PM | #1 |
Replacing the "ends" of the bed ( where the brake lights are.
How do you replace the ends of the bed?
This
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-28-2010, 02:29 PM | #2 |
1961 crewcab
Re: Replacing the "ends" of the bed ( where the brake lights are.
they were spot welded originally from the factory, but I think it was done before the stake pocket was welded on, also they probably used one of those spot welders that looks like a giant pair of tongs to reach up in there..
easiest way would be to eliminate the seam, and just weld along it, I am curious too, to see if anyone has a solution for retaining the original appearance.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-28-2010, 04:10 PM | #3 | |
Rollin' Old Skool
this is the response i got from Tony (LilRed66) when i inquired about bed end panels:
someone filled the backup light holes on mine, but they didn't do a good job since you can see the outline where they were....i'll probably just get the holes re-cut & install new backup lights |
07-28-2010, 04:44 PM | #4 |
Thanks guys! I filled mine way back 20 years ago cuz I couldnt find any tail light assemblies and buckets so I welded them up and put a home made roll pan with 4-39 F*&d tail lights and now I wanna change...... I might not.
07-28-2010, 05:11 PM | #5 |
Why couldn't you use a cut off wheel to remove the old parts, then locate the factory spot welds and drill them out. Then plug weld the new parts back on in the same spots the factory welded the originals at the factory?
That's what I did on the stake pockets on my stepside. Seems like the same procedure would work for these panels also. But that' purely speculation on my part. Last edited by lakeroadster; 07-29-2010 at 08:09 AM. |
07-28-2010, 09:29 PM | #6 | |
1961 crewcab
07-28-2010, 09:31 PM | #7 |
1961 crewcab
just a thought...what if we do like lake roadster said with the spots, and then use panel adhesive to glue it together....?
maybe alans classic will cjhime in on wether that would work...
07-28-2010, 10:07 PM | #8 |
you have to remove the entire stake pocket assembly to get to the spot welds on the tail lamp panel.there is no other way it can be done and retain an original appearance.this was the way it was done at the factory.the bedside has to be removed,stake pocket removed and then you can get into the spot welds and remove the tail lamp panel from the bedside.then reattach new tail lamp panel with spot welds.then reattach stake pocket with spot welds.not too easy of a job,but not impossible either.good luck
07-28-2010, 10:28 PM | #9 |
#16876
I'm going to find out real soon. I bent up the original one. I plan on spot welding the body side in and mig the gate side in a few spots. Removing the old one was fairly easy with an air chisel. There will be spots that I cant get to but the metal is so heavy I don't think it will matter after I get everything welded and the supports connected.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
