![]() Join Date: Dec 2006
big block help
Hey guys I need some help, a friend of mine just got a blazer w/ a bb. It isn't installed yet and he's wondering what it is going to take to get it in there. I don't spend a lot of time in this forum so I figured I would ask the experts.
Thanks Ian |
Re: big block help
Thanks Yukon that helps a lot!
![]() Join Date: May 2007
Re: big block help
If you change the transmission at the same time for a longer one, such as a 400 instead of a 350, you can move the engine forward. This will prevent having to modify the firewall, which is a lot more work as Yukon can tell you. If you add a longer trans, you can also leave the transfercase and transmission mount in the stock location, eliminating having to relocate more stuff and having to modify your driveshafts. Do a lot of research before hand, so you can decide what route you want to take, as far as modifications go. Go luck on your big block swap!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#5 | |
Old School, New Style
Re: big block help
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
