07-30-2010, 07:34 PM | #1 |
which radiator/tranny cooler?
It is time for me to purchase a radiator for the '59. It has a 375hp small block and 700r4 tranny. I was going to purchase one of Jegs' 22x19" universal radiators. I have seen that other guys have done this. What would I do to keep my tranny cool? Can I use one of these radiators? What do you guys do to keep your transmissons cool? Thank you for the help!
Nik radiator: http://www.jegs.com/i/JEGS/555/52005/10002/-1 Tranny cooler: http://www.jegs.com/i/Flex-a-lite/400/3826/10002/-1
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
07-31-2010, 12:05 AM | #2 |
Re: which radiator/tranny cooler?
any thoughts? I guess i'm asking if one of these heavy duty 10" x 20" x 3/4" tranny coolers would be enough to keep the tranny cool?
07-31-2010, 11:53 AM | #3 |
Any one? Am I heading in the wrong direction here? I wanted to get this radiator ordered but not if its not going to work for me. Maybe i'm just being cheap!?
07-31-2010, 12:07 PM | #4 |
Chevy Lover Till The End.
Hey feller, I went with the Cool Craft radiator for my BBC '69. It hasn't got here yet as they build them to fit as original & I also ordered an Aluminum shroud. Check them out, on Ebay or the website.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
07-31-2010, 12:12 PM | #5 |
Here is the link to thier Ebay store http://stores.ebay.com/Cool-Craft-Components or you can google them.
07-31-2010, 12:22 PM | #6 |
Thank you. I appreciate the help
07-31-2010, 01:20 PM | #7 |
No problem, let us know how it works out or which one you go with.
07-31-2010, 03:42 PM | #8 |
While We make some nice aluminum bolt-in radsm I think the 22x19 should be OK. Based on surface are and fin count, it should be able to cool about 380hp, - without A/C. If you can fit the 24 x 19 (and it will), use that one, it cools to about 405 hp, or 365 w A/C.The trans cooler your looking at is fine, mount it as low as you can.
07-31-2010, 08:39 PM | #9 |
Thank you Rob! I appreciate hearing that! that i can even get away with the 24" radiator. That helps a lot
Nik
08-01-2010, 12:44 PM | #10 |
No problem, remember that the factory style 'in tank' trans coolers were very small. I usually use a 24" tube style coolermounted below the rad, or on the frame rail (outboard - pass side) try not to blocck air from the rad. Also, make up some trim pieces to force air from the grill area to go through the rad, not around it. I fab them up from .065 alum. and trim them with edge guard. Every little bit helps in the desert.
08-01-2010, 01:40 PM | #11 |
When I converted to auto trans in 85 I used a condenser out of a vending machine mounted in front of the radiator. This time I put it off the frame under the cab. I allowed for a temp gauge and room for a fan if it does not get enough air.
