07-31-2010, 07:16 PM | #1 |
Best tailight?
So I have seen the tail lights on LMC and stuff I kinda like the smoked euro lights but I don't want my truck to be super flashy, does anyone have pics of them on their squares that I could take a look at too see how they look, or else any other aftermarket taillights for our trucks. considering the fact I got a ticket today for "modification" of taillights. Anything would help guys thanks in advance
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
07-31-2010, 07:23 PM | #2 |
Master Procrastinator
Re: Best tailight?
Take the stockers off and a light wet sand followed by the spray tint, saw it today on a 70's style blazer, said it was a rattle can product you can buy at any auto parts store and it's only $25a can, looked better than any of the aftermarkets I've seen and way cheaper
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
07-31-2010, 07:30 PM | #3 |
Re: Best tailight?
07-31-2010, 07:35 PM | #4 |
is very serious
Re: Best tailight?
you wanna vht night shades at oriellys and its only like 17 used my self a couple times on my freinds viehicals and you will want to use a real fine grit sand paper after you do like 3 or 4 light coats... wet sand before and after then bufff.... then look painted till you hit the brakes... but only 3 or 4 coats or the police will say they cant seee them
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold 1969 C-10 2wd fleetside LB 327 3spd - sold 1969 C-10 2wd fleetside LB 350 th350 - sold 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
07-31-2010, 08:27 PM | #5 |
Re: Best tailight?
it's good stuff, but you need to know what your doing. I seen some people put too many coats on and they got busted.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
08-01-2010, 12:08 PM | #6 |
is very serious
Re: Best tailight?
yea and too many coats applyed to fast will cause cracking and then it looks like .....
08-01-2010, 12:28 PM | #7 |
6.0 powered square
Re: Best tailight?
I'd say stock lenses with Led lights from lmc
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=75
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-01-2010, 12:32 PM | #8 |
house of chevy's
Re: Best tailight?
here are som aftermarket ones i have on my truck
1987 m1028 cucv d30 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" |
08-01-2010, 06:58 PM | #9 |
Re: Best tailight?
heres a Q should the vht be sprayed inside or outside the lens?
edit: what about getting a stock style unit with a black cover? cool looking when its light out and removable
08-02-2010, 12:35 PM | #10 |
Re: Best tailight?
Here is a shot of mine, I did these by mixing black paint into clear and spaying wet sanding and buffing them back to be shiny, I have used the vht night shade and it works good if you can spray the inside of the lense but if you have to spray the outside it will not be shiny when finished it will be a more dull look, or at leats that was my experience.
"WIDER IS BETTER" (TRUCKS ONLY) |
08-02-2010, 12:45 PM | #11 |
Re: Best tailight?
i replaced my tail lights too long ago to remember, can the inside of the lenses on a fleetside be sprayed?
08-02-2010, 04:13 PM | #12 |
Re: Best tailight?
08-02-2010, 04:57 PM | #13 |
Re: Best tailight?
sweeet i'll post pics in here if i decide to do it
08-02-2010, 07:12 PM | #14 |
6.0 powered square
Re: Best tailight?
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 08-02-2010 at 07:14 PM. |
08-02-2010, 07:16 PM | #15 |
Re: Best tailight?
i think nothing looks better on these trucks other than a shiny new stock lens
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
08-02-2010, 07:22 PM | #16 |
6.0 powered square
Re: Best tailight?
yep and with the led lights make them even better
08-03-2010, 09:35 AM | #17 |
Re: Best tailight?
08-02-2010, 08:22 PM | #18 |
Re: Best tailight?
Wow guys thanks for all of the insight, I think I'll just go with some new stock lenses with LED lighting like flamin did, Thanks again
08-03-2010, 09:43 AM | #19 |
6.0 powered square
Re: Best tailight?
from lmc it was easy to install no cutting just wiring
08-03-2010, 10:20 AM | #20 |
Getting Old; Going Broke
Re: Best tailight?
I still get a big smile every time I see those LED tail lamps. They just look amazing. I'm gonna have to do that.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
