Old 08-01-2010, 01:44 PM   #1
rusty baker
'70 C-10 Primer
rusty baker's Avatar
Fuel filter
Did these trucks originally have a fuel filter? Mine has the original steel gas lines and no filter. Did they have an undercab filter like some of the other trucks? I would hate to cut the lines to put in a filter. It's a 1970 with a 250.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 08-01-2010, 01:49 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Fuel filter
It was probably inside a fitting on the carb where the fuel line scres into. Maybe a brass or paper element.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 08-01-2010, 01:50 PM   #3
rusty baker
'70 C-10 Primer
Re: Fuel filter
No in -the -tank -screen or undercab filter?
Old 08-01-2010, 02:05 PM   #4
hayhauler71
hayhauler71's Avatar
Re: Fuel filter
fuel tank sock on fuel sending unit
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 08-01-2010, 02:45 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
Re: Fuel filter
The only filters these trucks had from the factory was in the inlet of the carb, very small filter. There also is a sock style filter on the fuel pickup in the tank.
Some people take the small filter out of the carb and put a larger filter between the fuel pump and the carb.
It is not recommended to put a filter between the tank and the pump because it could cause vapor lock problems.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-01-2010, 02:52 PM   #6
rusty baker
'70 C-10 Primer
Re: Fuel filter
Thanks, just wondered. Guess that 1 year old fuel pump is gone. All the Ford trucks and vans had an undercab filter. I have a bad hip and have trouble crawling under anymore.
Old 08-02-2010, 12:53 AM   #7
kevmic28
kevmic28's Avatar
Re: Fuel filter
Why do you say the fuel pump is gone? Im having an issue with mine in that it gets vapor lock. Not because of the fuel filter but because its so damn hot outside (100 plus today) combined with the intake temps Im boiling the gas inside the carb causing a vapor lock in my line from the pump to the carb. Im going to pick up a carb spacer tomorrow and that should finally solve my problem. I have a stock intake and a rochester carb. It has a small plastic spacer but its like only a 1/4 inch thick.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 08-02-2010, 09:46 AM   #8
rusty baker
'70 C-10 Primer
Re: Fuel filter
I'm not getting gas out of the pump.
Old 08-02-2010, 09:57 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
Re: Fuel filter
Have you checked the two rubber hoses in the fuel line? There is one under the cab and one at the suction side of the fuel pump. Mine had cracks in them causing the fuel pump to suck air.
Before you replace your fuel pump you should disconnet the suction hose and blow a little air pressure back into the tank to make sure it is not a plugged line. First take the gas cap off before applying air pressure.
Old 08-02-2010, 04:57 PM   #10
rusty baker
'70 C-10 Primer
Re: Fuel filter
I'll try that if it ever cools off. It's 103F right now with 120F heat index.
Old 08-02-2010, 05:28 PM   #11
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Fuel filter
Good lord. Why am I moving back there when I retire?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-02-2010, 05:49 PM   #12
rusty baker
'70 C-10 Primer
Re: Fuel filter
This is me today.
Old 08-02-2010, 06:10 PM   #13
Shyguy
Junior Member
Shyguy's Avatar
Re: Fuel filter
I thought it was hot here in flatlands of Southeast Missouri, but it is cool compared to where you are.
The humidity here is unbearable though.
Old 08-02-2010, 06:22 PM   #14
rusty baker
'70 C-10 Primer
Re: Fuel filter
They say it will only last til October.
Old 08-04-2010, 03:33 AM   #15
raycow
Re: Fuel filter
Before you unbolt that pump.....
Disconnect the inlet line, hold your finger over the port, and have a helper crank the engine. Do you feel any suction? If yes, don't replace the pump unless you have just plain run out of other things to do with your money.
Ray
raycow is offline   Reply With Quote
Old 03-11-2013, 10:22 PM   #16
jondancer
Re: Fuel filter
Can you get replacement filters for the original carb?
jondancer is offline   Reply With Quote
Old 03-11-2013, 10:24 PM   #17
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Fuel filter
Yes.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-11-2013, 11:05 PM   #18
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: Fuel filter
Anybody try an electric fuel pump with a fuel filter on it with an otherwise stock truck (meaning, tank in the cab, no FI, etc.)?
Right now, I'm replacing the fuel delivery system from a newly and properly cleaned (boiled out) up to the carb.
And, I'm always wondering about even NEW fuel pumps.
I'll try the "suck test", raycow offered back in 2010 (thanks for that, BTW), but wouldn't it be nice just to block it off and call it "done"....
....Time, and technology, marches on, no?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
