power steering? is it worth it?
i was thinking of taking my power steering off, to have less things to worry about and well as gain some power.
my front tires are around 25x5 will this be a pain to drive? |
Re: power steering? is it worth it?
Manual steering is great for driving around. Your way less likely to oversteer and you can feel the road a lot better. Parking is the issue. You have to plan where your going to put the truck. So long as your moving turning the wheels wont be bad but sitting at a dead stop is the problem.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#3 | |
Cars have had manual steering for a lot of years.Up into the 90's it was still possible to buy a brand new car with manual steering. Most race cars have manual steering for the weight savings. The box is lighter plus you get rid of the pump and the lines. If your not planning on driving it around daily it wont be much of a hassle.
#5 | |
Whichever way it was setup already I would probably keep it that way. To me losing a few pounds and gaining a couple horsepower isnt worth losing the convience of being able to easily park.
well i have to stuff to have power steering or no power steering, im gonna try both ways and see for myself i guess.
I had power steering on my chevelle and took it off in the search for power and weight savings, I kept the power unit just in case but have had it in the corner for 5yrs now. I have to say that i miss it even just driving around but manual ain't so bad. my only problem is i put the line lock on my steering wheel and if you make more than 1 turn the cord gets tangled on the turn signal handle
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
You go manual... i will keep my power steering
My 63 had power on it when I bought it with the SBC.. It was horible!!! I kept it at first with the LS1 swap. It would not come back to a straight line.. Kept left or right, where ever I had pointed the wheel. I had as much caster as posilbe. Still would not return. Went to a manual box.. What a difference!! I have a 205/28 tire in the front and it is easy to turn. Would never go back in the truck!! Much more of a positive feel when doing triple digits..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
I agree with super73 much better feel when i switched to a manual box
Brandon Street Car Mafia |
thanks guys
I have a bypassed power steering box on my race truck and it is pretty hard to turn when I have my normal wide street tires on. But when I run skinnies on my truck (it looks like you do too), turning feels super easy. I've been told that a manual box is easier to turn than a "dry/bypassed" power steering box. I haven't bought a manual box yet, but I will when I find one in my area cheap enough. I say go for it.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
#14 | |
#15 |
Manual box will build you or your ol lady some muscles around town. Mostly highway or drag race, manual is great. Alot of around town you will be happy with power. i dont miss my manual trans or steering since i changed. All i need now is AC.
#16 |
to really enjoy the manual steering change to a 13"steering wheel too
#17 |
If your gonna go 13" do it right with a 13" Chain wheel..
#18 |
cant you change the ratio or something ive been hearing?
#19 |
![]() Join Date: Jun 2006
Yes a quick ratio box is like 12:1 and a lock to lock is 2 turns if I remember correctly. If you dont want the fluid all in one unit they sell one with a tiny pump on the engine with the fluid res mounted anywhere you want.
#20 |
I had my power steering hooked up,first pass down the track truck was all over the place on the top end.Took the belt off and now it is 100 times better,a little tough on turns but thats ok.Just put the belt back on for the street.
