Old 08-04-2010, 01:20 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
73-87 swap?
What all is involved? I want to take the front clip and rear axle from a 85 C10 and put it in a 60-66(not sure which year yet). I know I will have to weld perches on the new axle if the 60-66 is trailing arm susp. I will be also putting in a Hydroboost system. Thanks.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-04-2010, 11:04 AM   #2
structures
structures's Avatar
Re: 73-87 swap?
http://67-72chevytrucks.com/vboard/s...d.php?t=409676
this guy did the front clip thing. I think it's a pretty great idea. Wish I would have thought of it.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 08-04-2010, 07:16 PM   #3
thirdstreettito
Resident of Here
Re: 73-87 swap?
Thanks, anyone else?
~Bradley~
Miss having a truck
Old 08-05-2010, 12:39 AM   #4
Captainfab
60-66 Nut
Re: 73-87 swap?
That has been done by many, many, many people. It is a very common way to convert to disc brakes....the best way IMO. Here is a thread with a bunch of info in it on the front upgrade. I did my first one almost 30 years ago.
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
The rear conversion is pretty straight forward, as it sounds you are aware. You'll need to weld on trailing arm mounts as well as a panhard bar mount. The '71-'87 differentials are 1.5" wider overall.
Let me know if you need any brackets for your hydroboost conversion, as well as the power steering box adapter plate.
