Old 08-05-2010, 08:39 AM   #1
Laid_Out_50
Laid_Out_50's Avatar
Rear Notch Kit
For the guys running airbags and who have the rear of their frames notched where did you get your notch kit? Was it a universal kit or was it specific for AD trucks?
Laid_Out_50 is offline   Reply With Quote
Old 08-05-2010, 03:21 PM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: Rear Notch Kit
Big (step) notch or small c-notch? I got a c-notch from CPP, it was for the wrong frame so I made my own. Do not get one from them... If you are going that route, just find a thick-wall steel pipe, 4" or 6" use that and plate the inside too.
Big notches can be bought from www.***************** and they are universal, I don't know of any specifically for AD trucks.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-05-2010, 03:48 PM   #3
robnolimit
robnolimit's Avatar
Re: Rear Notch Kit
We, No Limir, have a rear boxing plate & C-notch kit for $71.00 they are made to fit your chassis (model specific) A regular C-notch will only get you another 2", then the top of rhe housing smacks the bed floor. If you go any lower than that, you have to raise the bed floor.
robnolimit is offline   Reply With Quote
Old 08-05-2010, 03:52 PM   #4
Tchia65
Re: Rear Notch Kit
Rob, I bought one of your chassis kits and am in the process of installing it. Question is how low will the kit get me? I've searched for pictures of task forces with airbag wide ride ifs and found nothing.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 08-05-2010, 05:01 PM   #5
pipty6
Re: Rear Notch Kit
since yor in the Bay area, give Gambino Kustoms in San Jose a call. He has a universal notch you can use. Basic monster notch, you can cut to fit how deep you want it.
pipty6 is offline   Reply With Quote
Old 08-05-2010, 07:28 PM   #6
Laid_Out_50
Re: Rear Notch Kit
He wants to charge me $140 for a supposed AD truck specific kit.
Old 08-05-2010, 07:44 PM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Rear Notch Kit
Just make your own, its not hard to do.
Kabwe is offline   Reply With Quote
Old 08-05-2010, 08:02 PM   #8
GRIMSS
GRIMSS's Avatar
Re: Rear Notch Kit
Yep, just make your own. A lot of people use 2x4 steel tube, I used flat steel plasma cut to the shape I wanted.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 08-05-2010, 08:11 PM   #9
Laid_Out_50
Re: Rear Notch Kit
How tall should I make it using 2x4 stock to lay running board and not really raise the bed like tylerdurben does to his trucks
Old 08-05-2010, 08:31 PM   #10
GRIMSS
GRIMSS's Avatar
Re: Rear Notch Kit
You need to know the largest tire you're planning on running and the size of the axle tube.
You also need to know the measurements of the frame when the board are on the ground.
2001 GMC SIERRA
1968 Camaro
Jared
Old 08-05-2010, 08:48 PM   #11
fabguy
Elev8r Man
fabguy's Avatar
Re: Rear Notch Kit
Making your own is very simple. I am going to start making mine this saturday although it is a little easier for me since I have a 35 ton press brake. If you need one bent up this weekend, hit me up then swing by my shop I will hook you up.
Thanks,
Fabguy
fabguy is offline   Reply With Quote
Old 08-06-2010, 12:04 AM   #12
Laid_Out_50
Re: Rear Notch Kit
Thanks,
Fabguy
Thanks Fabguy but your a little to far away for but take some pics when you make it and when you install it.
LaidOut
Old 08-06-2010, 05:33 AM   #13
slimneverdies
slimneverdies's Avatar
Re: Rear Notch Kit
Pretty easy to do. I took some 2x4 - 3/16" square tubing and cut the ends on 35* angles. Take the rearend out and lay the truck on runningboards and mock it from there. I had to do mine twice cause I tried to measure while the truck was at ride height and made the notch to tall. Had to redo the top section and brig it down by 3 - 1/2". I even made a crossmember for my 4 link to attach to the frame using the same notch design
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-05-2010, 09:10 PM   #14
robnolimit
robnolimit's Avatar
Re: Rear Notch Kit
Tchia65, If you have stock hieght spindles, when the truck is at ride hieght, the rockers should be in the 5" - 6" range. Dropped will be 4 1/2 " lower. tire size makes a difference.
Old 08-09-2010, 09:10 PM   #15
Laid_Out_50
Re: Rear Notch Kit
That looks simple enough to make
Old 08-15-2010, 09:18 PM   #16
Laid_Out_50
Re: Rear Notch Kit
Anyone use the Welder Series step notch kit?
Old 08-16-2010, 02:56 AM   #17
sgtusmc
sgtusmc's Avatar
Re: Rear Notch Kit
I have one. I paid the extra $10 bucks to have it welded. I havn't glued it on yet. Nice quality and fast shipping. I think there's a pic of it in my '59 thread.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 08-31-2010, 07:42 PM   #18
4DSEVEN
4DSEVEN's Avatar
Re: Rear Notch Kit
I have the Welder Series step notch and also their 4 link. I am using the original frame and it gets me pretty much on the ground with 18" wheels.
I am very pleased with their products and the prices are very fair.
The truck is sitting on a couple of 2x4's in the front right now so the floor board is riding up.
4DSEVEN is offline   Reply With Quote
Old 08-16-2010, 10:01 PM   #19
Laid_Out_50
Re: Rear Notch Kit
Looking to getting the WS kit it gives me 7 1/2" of extra travel that should be enoughtto lay the running boards on the ground while running a 255/35/20 tire and puts my ford explorer rearend at 15 1/4" to the top of axle from the ground. Will I have clearence issues with the rear fenders when I lay it out with such a wide tire?
Old 08-19-2010, 08:17 PM   #20
Laid_Out_50
Re: Rear Notch Kit
I was looking on ***************** and saw there notch kits and they look like the ones the Tylerdurden uses on his trucks.
http://www.*****************/notches/8-pc-step-notch-kit
Old 08-25-2010, 12:57 AM   #21
Laid_Out_50
Re: Rear Notch Kit
Should I go with a suicidedoors kit a welder series kit or a Gambino Kustoms kit?
Old 08-25-2010, 01:38 AM   #22
project67-stepside
project67-stepside's Avatar
Re: Rear Notch Kit
call nate at porterbuilt he told me he was workin on some stuff for ur year trucks...
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 11-07-2010, 02:25 AM   #23
Laid_Out_50
Re: Rear Notch Kit
What size tires are you running on your 18's. Are you running a Ford 8.8" rear end?
Old 11-11-2010, 01:57 PM   #24
4DSEVEN
4DSEVEN's Avatar
Re: Rear Notch Kit
I'm running the following tires;
Rear tires - 275 35 18
Front Tires - 235 40 18
Wheels front -18x8.5
Offset front - -5.3
Wheels rear - 18x10
Offset rear - -5.0
Yes, running with an 8.8 rear.
Old 11-10-2010, 04:08 PM   #25
cajundragger
Re: Rear Notch Kit
I dont think 7.5 is big enough. I dont remember how big mine is.
the frame is exactly 4" off the ground when the running boards lay. Like the flat section under the cab.
but this much notch....
gets you like this laid out on a 27" tall tire...
Im sure some of the guys here saw my truck at Dallas and can comfirm it lays hard on the ground.
cajundragger is offline   Reply With Quote
