07-31-2010, 06:55 AM | #1 |
Can you help me ? need plumbing diagram
Can you help me ?
I have purchased an air solenoid block and need plumbing diagram as i dont have one, i have tried searching the internet but no luck, Airridepro.com Model;vs5338 (see pictures) I also need 4 x air bags for my 63 c10, can you please indicate which bags i should use, Many thanks Darron (uk) |
08-05-2010, 03:59 AM | #2 | |
Re: DO NOT OPEN- Air Ride Technologies inside
Port 1, in the manifold is the pressure source. Port 2, in the valve body, plumb to air bag. Port 3, in the manifold, exhaust. Port 4, not on your valve body. Port 5, in the manifold, exhaust. There are essentially 3 functions going on in this valve. The one pictured is the static state where all ports are closed and no air can move through it. When You energize coil 12 it pulls the thimble towards it moving the left function block in -line with the ports, connecting port 1 to port 4 and port 2 to port 3. Port 4 does not exist on you valve so no action there but port 2 (air bag) is now open to port 3 (exhaust) ==> lowering. When You energize coil 14 it pulls the thimble towards it moving the right function block in -line with the ports, connecting port 5 to port 4 and port 2 to port 1. Port 4 does not exist on you valve so no action there but port 2 (air bag) is now open to port 1 (air tank) ==> raising.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
