Old 08-06-2010, 11:43 AM   #1
sierragrande77
cab mounts for 77
I have checked around and looks like you can't get new cab mounts for a 77. Will the 81-87 mounts match up to my frame, or will I have to drill new holes?
sierragrande77 is offline   Reply With Quote
Old 08-07-2010, 09:57 PM   #2
ray_mcavoy
Re: cab mounts for 77
Hmmm ... I just checked the LMC catalog and they're still showing cab mounts available for 73-80 in both OE style rubber and performance polyurethane.
I don't think the cab mount locations changed so you probably wouldn't have to drill any new holes to use 81-87 style mounts. Height might be a concern though. For example, 73-80 3/4 and 1 tons as well as 1/2 ton 4x4's used taller rear cab mounts than 73-80 1/2 ton 2wd or 81-87's. So spacers would be necessary to make 81-87 mounts fit those applications.
ray_mcavoy is offline   Reply With Quote
Old 08-09-2010, 10:33 AM   #3
sierragrande77
I am sorry, I spoke wrong before. I meant the bracket-body mounts. (19) In the lmc cat on page 35 in the new catalog. They do not have these for 73-80. Will they be the same? I have the correct cab to frame mounting kit.
Old 08-08-2010, 01:12 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the cab mounts are readilly available from several vendors . You must use the cab mounts compatible to your frame or the cab will not sit right
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
