was there a 1968 k10 custom
going to be building my truck (taking a 1968 c20 long box, putting it on a 71 swb cst frame, with 1969 k5 drivertrain) and since its gonna be so far from original its stupid i was curious if there was a 1968 k10 custom in existence. considering doing the chrom accent trim. also this truck will get my 396bb.
thanks, david |
Re: was there a 1968 k10 custom
That is basically what I did. I used 69 swb frame and bed with the 72 front axle and a 73 14 bolt in the rear. I used a 69 CST cab and then put a lot of aftermarket accessories on it. FI 383 with a T400 and GV overdrive with 4:09 gears. Has a 4 in lift with 35 in tires
69 Chevy 4x4 383 Power ![]() |
did you use blocks or new leaf springs? also whats the rim size/backspacing.
Thanks! David |
The rims are 12x16.5 and I believe the backspace is 6 in. I used a two in block and a 2 in shackle lift on the back. on the front it was all done with the spring brackets and shackles.
also do you have any pics you could email me? side profile, front, just varying angles?
thanks again |
If you go to my profile I have some pictures in an album there. I will try to upload some more tomorrow.
