Old 08-12-2010, 06:59 PM   #1
72GMC-Burb
72GMC-Burb's Avatar
BBC in 72 GMC Burb - exhaust help~
I have pics of my burb posted here and appreciate all of the insight I get from reading other posts and seeing the pic's - great work everyone!! I am wondering if anyone else has done the move that I have....2" forward so the engine would clear the firewall? If so, how do you work in headers without having to give up a left arm and leg?? i had to notch the frame to get it all to clear where it tapers up by the exhaust - and - now I would love to have better looking pipes if anyone can steer me in the right direction. Please and thanks
72GMC-Burb is offline   Reply With Quote
Old 08-12-2010, 08:06 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: BBC in 72 GMC Burb - exhaust help~
why would you need to move the engine forward? My big block clears the firewall no problem
Old 08-12-2010, 08:38 PM   #3
72GMC-Burb
72GMC-Burb's Avatar
It is a 72 GMC 4x4 - she was originally a SBC - and I got a wild hair to go crazy - so I had a 454 built up - when I went to put everything in - it kept hitting the firewall - I talked with Dave @ Early Classic - he said to move everything forward 2" - I am not sure the 72 4x4 came a big block - if it did the crossmember must have been different - not sure - even moving 2" forward - the HEI is still about 3/4" from the firewall -
Old 08-13-2010, 03:25 AM   #4
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
There's a whole thread on the board here dedicated just to BBC engines in 4x4s. I had to chop and weld my firewall on both sides to fit my 454 without modifying the mounting points of the motor itself. I've got a set of headers hooked up to it (had a SBC w/ headers before and I already had a small notch in the frame) and the only problem I have run into is on the passenger side where the tube hits the bottom shackle bolt. My best approximation to a solution in my case is going to involve a ball peen hammer applied directly to that area.
BTW, no 4x4 came with a BBC from the factory in our year range.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 08-13-2010, 06:17 AM   #5
72GMC-Burb
72GMC-Burb's Avatar
Thanks Beezleburb!
I have had people tell me there were BBC's in them - but I chose to believe otherwise!
Old 08-13-2010, 12:53 PM   #6
Sublvr72
Sublvr72's Avatar
mine clears fine with the big block motor mounts installed.
Sublvr72 is offline   Reply With Quote
