Old 08-13-2010, 08:16 PM   #1
60apache
60apache's Avatar
wiring harness anyone used this
found this at jegs anyone ever used it? pros and cons thoughts? it seems much cheaper than others I have found.
http://www.jegs.com/i/JEGS/555/10400/10002/-1
60apache is offline   Reply With Quote
Old 08-13-2010, 09:25 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: wiring harness anyone used this
I`ve used this before in another project....turned out nice...
http://www.ezwiring.com/wiring_harness.html
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-13-2010, 10:04 PM   #3
halfcockedcustoms
halfcockedcustoms's Avatar
http://www.rebel-wire.com/wirekits.shtml
halfcockedcustoms is offline   Reply With Quote
Old 08-14-2010, 01:10 AM   #4
HSkinner
How many circuit do you usually use?
HSkinner is offline   Reply With Quote
Old 08-14-2010, 02:14 AM   #5
blackedoutharley
http://www.summitracing.com/parts/PRF-10112/
blackedoutharley is offline   Reply With Quote
Old 08-14-2010, 11:38 AM   #6
60apache
60apache's Avatar
Originally Posted by blackedoutharley View Post
explain why I would want to spend $154 more on this kit?
Old 08-15-2010, 08:15 AM   #7
lakeroadster
Originally Posted by 72lb4x4 View Post
I think its all a question of how much time you want to spend and how much wire splicing you want to do. The less money you spend initially, the more work and splicing of old wiring and connectors to new wiring there will be.
I agree with 72lb4x4. If you look at these kits closer:
The Summit "Painless" kit is a 12 circuit specifically made for a Chevy/GMC Truck. Look at the photos in the above links. You will see this kit has items such as the dash lights, etc. pre-terminated so it's more of a plug and play harness. $414.95
The Jegs kit is a 18 circuit universal that you cut to fit. But it appears it has all the terminations you will need for custom gauges. It will not have the plugs you need if you are using a stock factory gauge cluster. $259.99
If there are modifications to your truck, such as different gauges, then the universal kit makes sense.
I hope this helps.
lakeroadster is offline   Reply With Quote
Old 08-17-2010, 01:44 AM   #8
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I hope this helps.
Personally I prefer to have the ability to cut and trim mine to fit. Just like I always buy spark plug wires, the "pre-fit" ones always seem to have too much excess wiring that ends up being a little tacky. It is just my opinion, but I do like doing a lot of the fit and finish stuff myself, I belive it comes out looking a lot nicer. I am fairly experienced with automotive electronics so I normally don't get too intimidated by it, and actually I enjoy it more often than not.
TheDark1: I will be doing a complete re-wire of my '65, and will post pics and info in my build thread. It may just be a while before I get that far.
fryer1979 is offline   Reply With Quote
Old 08-16-2010, 02:28 AM   #9
blackedoutharley
Like stated above it is a an application specific kit engineered for your truck. The wires are all marked as to exactly where they go (trust me, this helps a lot!).
It is a matter of convenience. And sometimes convenience is more costly (and worth it!).
Old 08-14-2010, 02:43 AM   #10
laid_out_70
laid_out_70's Avatar
i used painless wiring in mine. works great. most of the wires comes with specific connectors and what not
laid_out_70 is offline   Reply With Quote
Old 08-14-2010, 08:33 AM   #11
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Kits like that one, and the comperable Summit kit, seem to work pretty well. All of the cars I have seen them installed into turned out nicely, the guys installing them said they were relatively easy and the instructions were well laid out. Of course painless is nice, but you pay a lot more for a name. Truthfully, from what I've seen of the painless kits there isn't much difference there to justify the almost doubled price. I'll be using a kit similar to the Jegs or Summit kits in mine (if not one of those two).
Old 08-14-2010, 08:46 AM   #12
lakeroadster
X2
I wired my (2) hot rods (Model T and Model A) using Painless Wiring kits and they worked out great. Back when I bought those kits Painless and Ron Francis were the "class acts" in wiring. But their pricing is out of line now, IMHO. Nowadays Painless wants $500.00 for a 12 circuit system! The Rebel Wire kit linked above http://www.rebel-wire.com/wirekits.shtml has a 9 + 3 kit for $150.00.
Rebel even has a remote mount fuse box kit for less than $250.00. I am wanting to mount the fuse box in my center console for ease of accessibility. Whoever came up with the concept of mounting the fuse box on the firwall was a sadist, or a contortionist, or both!
Old 08-14-2010, 10:05 AM   #13
TheDark1
Intentionally Left Blank
TheDark1's Avatar
If someone rewires their truck, PLEASE PLEASE do a detailed post on it. I need to rewire mine and would like to save some headaches if possible. Let us know what you likes and didn't like and any trouble areas you had. Thanks, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-14-2010, 02:22 PM   #14
72lb4x4
You can spend over $1000 on new replacement harnesses and have it done in a few hours or $150 and who knows how much time.
The question becomes what's time worth, and what's the competence level or wiring skills of the installer. Then if it doesn't work, what troubleshooting skills does the installer have?
There's a video on youtube I think about the AAW classic update kit, which may be a good compromise. I haven't used their product so I'm just saying its out there...
72lb4x4 is offline   Reply With Quote
